Engine Labouring When Pushing The Clutch Pedal?
Posted 28 March 2015 - 12:13 PM
Can somebody help me troubleshoot the problem I am having.
When the car is running and I push the clutch down to select any gear the engine revs drop and the engine labours. When the car is cold the engine stalls when the clutch is pushed. The problem has got slightly worse since I have noticed it happening.
Some people say it's the clutch thrust bearing or the whole clutch??? Some people are saying that the crank is moving???
Any help much appreciated.
Harry
Posted 28 March 2015 - 12:53 PM
more likely you are pushing the crank against the thrust washers, check the throw of the clutch plunger - the two large nuts on the end of the plunger govern how far the plunger and clutch move.
Posted 28 March 2015 - 01:03 PM
Posted 28 March 2015 - 02:03 PM
Posted 28 March 2015 - 02:06 PM
Posted 28 March 2015 - 02:43 PM
Posted 28 March 2015 - 03:14 PM
Posted 28 March 2015 - 04:59 PM
Posted 29 March 2015 - 03:26 PM
what shall i do next have the clutch replaced the whole system or any other suggestions???
any help much appreciated:)
Posted 29 March 2015 - 05:26 PM
check the plunger throw, if you are jamming the clutch up against the crank and the crank thrusts you will pinch the crank and slow the engine and also wear the thrust washers especially if someone has bent the operating arm, sounds like you have too much adjustment (or throw) on the plunger
Posted 29 March 2015 - 06:48 PM
Posted 08 April 2015 - 08:40 AM
right progress, booked it with ML Motorsport for a new clutch and clutch arm including the pin. apparently i have way to much throw due to clutch arm being bent
Mini Technical Sections →
Problems, Questions and Technical →
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
Help Pls! Engine Not Starting, Not Sure What To Do!Started by TheYoungestGary , 08 May 2026 |
Overbored Or Supercharged 850 Rebuild?Started by kkonstantinopoulos , 04 May 2026 |
Su Hs4 CarburettorStarted by Murrayup , 21 Apr 2026 |
Missing Speedo Drive Clamp PlateStarted by JimmyStinkpickle , 18 Apr 2026 |
