Can't see why you need (2) solenoids when you are using a pre engaged starter why ?? and is that starter the right one for the flywheel they have different ring gears for inertia starters and pre engaged starters they work different way rounds.
Leaky bought the right wiring loom for the car, but not the right loom for the engine, hence the loom going to the solenoid on the wing... I'm trying to get it working the tidiest way for him. As far as I'm aware it's the correct starter for the flywheel/engine (It's not my car...) but it is turning over now, just not firing, but fueling and other wiring may be the issue.
I thought there was a red & white wire to the small terminal on the starter that comes from the ignition and in the picture you are bridging the wrong terminals.
With ignition on you should have feed to starter then you bridge the small terminal with the main cable.
I tried that, that's what the red wire is doing, turns out you need to bridge the main incoming and larger spade for it to turn over... So really the wing mounted solenoid is still doing all the work.
The pre-engaged as its own solenoid fitted, the wing fitted is for an inertia one.
Correct, we know that, I was asking about how to wire the starter motor to the solenoid and what connections need to be made.
