Hi;
Probably have this info lurking around somewhere but cannot find it, hence the post.
I just need some advice on painting steps for primer seam sealer etc.
Inside the Boot
After replacing the rear half of the boot and the outer arches I cleaned the floor dwn to bare metal and then applied 1 coat of Epoxy Mastic Primer, brushed in and then smoothed with a roller.
On the rear of the back seat I flatted down the existing paint but where there where scratches I took it back to bare metal and also applied Epoxy Primer.
Should I apply another coat of epoxy primer before I seam seal or should I seam sill and then apply another coat of epoxy or should I just use Cellulose Filler Primer on top of the Seam Sealer?
How many coats of primer?
Here's the boot at the mo.
Underside
After repairing the underside I stripped it back to bare metal and applied 1 x brush coat of Epoxy Primer smoothed with a roller.
Again should I apply another coat of Epoxy before the Seam Sealer, or should I apply the Seam Sealer and then another coat of Epoxy Primer?
I will then coat with U-POL Stone Chip and finally Top Coat with Cellulose.
Any advice on these steps would be appreciated, thanks
