oil in my radiator?
Posted 19 July 2006 - 05:41 PM
Posted 19 July 2006 - 05:42 PM
I think its the sign of not enough anti-freeze
Rich
Posted 19 July 2006 - 06:07 PM
Posted 19 July 2006 - 06:24 PM
i took the rad out then started and ran the engine, held e hose to the head whitch flushed it through for about 5mins and did the same with the rad now i have nice clean water
Edited by Ollie180, 19 July 2006 - 06:26 PM.
Posted 19 July 2006 - 07:08 PM
surely you didnt run your engine without a rad for 5 mins!?
Posted 19 July 2006 - 07:18 PM
i ran my engine without the rad and had the hose to the head so then only clean water was going through it and otu bottom hose
Edited by Ollie180, 19 July 2006 - 07:19 PM.
Posted 19 July 2006 - 09:21 PM
The rad is easy to do just turn it upside down and sick a hose pipe in were the bottom hose fits till you get clean water out the other end.
Then turn up the right way and repeat.
Once you have flushed the system trough top up with a 50/50 mix of antifreeze and water
Easiest way and to stop all the guess work of how much of what is in there, is to pre mix it in a 2 litter drinks bottle 1 litter of antifreeze and one litter of water.
Just don't use the bottle for any drinks afterwards and any you have left over can be stored somewhere safe for when, if you ever need to top it up.
Once the cooling system is full run the engine with the Heater in the on position and radiator / expansion cap left off for 20min to allow any air in the system to escape, top up if necessary
you should Do this every 2 years as not only does antifreeze stops your coolant from freezing in cold weather
But it also raises the boiling point of the coolant, which helps stop over heating in the summer
Helps to prevent corrosion in the system that could block the water ways causing overheating probs
And lastly lubricates the inner workings, water pump etc
Edited by 1984mini25, 19 July 2006 - 09:26 PM.
Posted 19 July 2006 - 09:59 PM
You need to pump it trough, as draining it alone will not remove all of it,
thats word i was looking for thanks for clearing it up lol
Posted 19 July 2006 - 11:29 PM
Posted 20 July 2006 - 12:07 PM
if i run the car for 20 minutes wont the water start coming out of the top when the cap is off?
what?????
Posted 20 July 2006 - 12:08 PM
Posted 20 July 2006 - 03:08 PM
my clutch has started slipping tho now. one problemo after another it seems
