Outer Cv Boot
6 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 05 April 2015 - 12:05 AM
My new outer CV boot seems to have a very loose fit on the axle end of the boot.  I am concerned that it will not clamp snugly to the axle and hence not provide an effective seal.  Is this the usual fit for the outer CV boot?
Attached File  PICT0009.JPG   74.4K   25 downloads
#2 Buzzbee
Buzzbee
    Just On Tickover
  • 6 posts
Posted 05 April 2015 - 12:15 AM
They look like a inner boot to me
Edited by Buzzbee, 05 April 2015 - 12:19 AM.
#3 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 05 April 2015 - 12:17 AM
Wrong boot. That is for the inner pot joint.  It should be like this:
http://www.7ent.com/...oe-gsv1053.html
Or like this:
http://www.7ent.com/...rt-gdg0233.html
#4 newenglandmini
newenglandmini
  • 646 posts
Posted 05 April 2015 - 12:20 AM
You are correct, I have the boots reversed.  Nonetheless, I have the same concern.  The boot (pot joint) does not fit snugly on the driveshaft.  By contrast, the outer (accordion) CV boot does fit snug on the driveshaft.
Edited by newenglandmini, 05 April 2015 - 12:23 AM.
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 05 April 2015 - 12:24 AM
It is not a tight fit but it should not rattle around either.
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 06 April 2015 - 01:03 PM
Sorry, i was not paying attention. The inboard (pot joint) boot does not attach to the driveshaft. The boot is inverted inside-out and then mounted with the clamp or cable tie to the pot joint where a groove is to prevent the boot from coming off. The clamp will end up inside the boot. Then the boot goes back inside-in and the larger end installed secured with a clamp or a cable tie.
Make sure to put grease in the driveshaft splines to prevent the driveshaft from getting stuck inside the pot joint with corrosion.
  http://www.reizendem...fronsusp/13.htm
Edited by xrocketengineer, 06 April 2015 - 01:08 PM.
#7 newenglandmini
newenglandmini
  • 646 posts
Posted 08 April 2015 - 12:20 PM
Many thanks for your advice and for providing the reference link.
