Megajolt Trigger Wheel Position
9 replies to this topic
#1 panch1989
panch1989
  • 235 posts
Posted 05 April 2015 - 09:59 AM
As above, anyone got a picture of the position of the missing tooth should be? Thanks
#2 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 05 April 2015 - 04:34 PM
The engine needs to see the missing tooth 90 degrees before TDC. Where you place the trigger wheel/sensor is irrelivent as long as you do that.
Phil.
#3 panch1989
panch1989
  • 235 posts
Posted 06 April 2015 - 08:31 AM
so it reads the sensor as Tdc? And the missing tooth has to be 90 degrees before that, is that correct?
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 06 April 2015 - 08:40 AM
Yeah, obviously it depends where you mount the sensor but the missing tooth should pass the sensor 90 degrees before TDC
#5 Ethel
  • 26,151 posts
Posted 06 April 2015 - 09:46 AM
1. Put your engine at tdc.
2. Put your crank sensor where you prefer.
3. Attach the trigger wheel so the centre of missing tooth gap is 90 degrees clockwise from the centre of sensor.
Most seem to have the sensor sticking out towards the front & mounted on the radiator/engine mounting bracket. Mine is tucked up under the alternator, so it's inside the path of the fan belt and doesn't interfere with replacing it.
#6 panch1989
panch1989
  • 235 posts
Posted 06 April 2015 - 01:13 PM
I've got the trigger wheels bracket and trigger wheel so the sensor is at the 7/8 position with the gap in the wheel near the tdc Mark. Is this 90btdc or 180 out
#7 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 06 April 2015 - 01:37 PM
http://www.autosport...or_installation
#8 panch1989
panch1989
  • 235 posts
Posted 06 April 2015 - 02:36 PM
without the megajolt plugged in the engine will crank but not start. However with the megajolt plugged in it won't turn over. I turn the key and get a groan from the starter
#9 Ethel
  • 26,151 posts
Posted 06 April 2015 - 02:44 PM
That sounds correct, I've edited my first reply to try and be clearer. You want the sensor to detect the gap @ 90 degrees before tdc, so if the gap is under the sensor the engine should be 90 before.
Turn it on 90 degrees (clockwise) and the gap will have gone 90 degrees past the sensor while the engine is now at tdc.
#10 panch1989
panch1989
  • 235 posts
Posted 06 April 2015 - 03:33 PM
Changed the spark plugs and he lives!!! Strange that
