I'm looking to make my own rear beam, of a similar design of some others on the market.
I have had the idea to use a long billet of aluminium, machined down with all the correct holes drilled in. then, where the radius arm brackets attach just tap into the billet and use stainless steel bolts.
However, will the threads in the aluminium be strong enough with the forces felt through them? if for example the beam is inch and a half thick the threads could be and inch long, if not longer. would they simply pull out?
The beam will be lightened between the mounts with holes.
