Emissions Dramas 92(L) Carb+Cat
Posted 07 April 2015 - 03:31 PM
The misses mini has just been through its MOT today. And it failed in the emissions. Trouble is it is a standard car with pea shooter exhaust etc. Its a 92 L reg, it has a hif38 and a cat as well. Iv just fitted a new cat and wound the mixture of a little but it still fails the emissions.
Now I don't want to wind the mixture so far off it barely idles. That's just masking the problem. I understand the required emissions test surround this age/type of mini is a bit of a grey area with different people saying different things. Il post the results below.
First fast idle test
CO <=0.3% Mine was 1.53%
HC <=200ppm 61ppm
Lambda 0.95-1.09. 0.96
Second fast idle
CO 1.55%
HC 68ppm
Lambda 0.96
Natural idle test
CO <=0.75% Mine was 2.27%
Just noticed on the test sheet it's got vehicle description 1.3l auto tbi engine and catalyst equipped vehicle with close loop control.
Am I being tested under the wrong criteria?
Posted 07 April 2015 - 04:22 PM
That aside, it appears that your car has failed the full CAT test, which it isn't actually required to pass as it's a carb model (that's assuming that it isn't an Spi that's been converted to carb of course). As I understand it, on a post 91 model, the tester is supposed to run a full CAT test first, and if it fails, then unless the engine is specifically listed in the emissions handbook (which carb engines aren't), they're supposed to then run the basic emissions test instead, which from memory allows CO at something like 3.5%.
Sadly this sounds like the all too common problem, of MOT inspectors at mainstream garages not understanding how the regulations are applied to older cars. To be fair to the inspector though, 94 was the crossover year between carb and fuel injection though, so that may be the cause of confusion.
Posted 07 April 2015 - 05:38 PM
Posted 07 April 2015 - 06:19 PM
Either way, if it's a carb model from standard, then it's not required to pass the full CAT emissions test and is only required to pass the lower basic emissions test.
The only classic minis that require a full CAT emmsions test are those first used after 31/07/1995 (with the last carb model being produced in 1994) and also those 92-95 models with following engine numbers: (all of which are fuel injection)
Mini Model Code XN:
1.3l Auto TBi Engine Code X Serial No 059845 onwards
1.3l Manual TBi Engine Code X Serial No 059822 onwards
1.3l TBi Engine Code Y Serial No 060488 onwards
1.3l MPi Engine Code Z
All others only require a Non Cat Test (i.e. - CO <= 3.5% HC <= 1200ppm)
Posted 07 April 2015 - 06:53 PM
Posted 07 April 2015 - 07:32 PM
That info is taken from the MOT/emissions handbook and I always assumed it referred to the actual engine number, (as opposed to the VIN/Chassis no), but then thinking about it, A-Series engine numbers tend to start numercialy to denote engine size/cc, not with an alphabetic prefix like "XN". So yeah maybe it is referring to the actual VIN/Chassis number instead (which from memory should begin with something like "SA" or similar, on a carb model like yours, as opposed to "XN"). Then again, I don't think I've ever had any dealings with fuel injection engine numbers, so I suppose it's possible that their engine numbers are in a different format.
Posted 07 April 2015 - 07:45 PM
I reckon the XN bit is the VIN number, just missing the first SAX bit, as my VIN on my V5 for my 92 (K) Italian Job starts SAXXN.....
So yes, MOT man has run the wrong test for a carb'd engine.
Posted 07 April 2015 - 07:49 PM
You could just lean it out for the MoT and then reset afterwards.
That way tyhe car is then road worthy, then you can fix the issue for good.
Posted 07 April 2015 - 08:05 PM
Posted 07 April 2015 - 08:10 PM
Posted 07 April 2015 - 08:17 PM
Your tester should really be running a basic test on the car!
But just to be sure type your engine number into the following website
http://www.guess-wor...Tech/engine.htm
if you cant work out how to use the site, pm me your engine number ( from your log book AND the engine, this way we can work out which type of engine is fitted
Posted 07 April 2015 - 08:24 PM
Finding an MoT tester, that can properly test Mini's seems to be a hard task! Even worse with the Injection ones. Was there not a thread with 'Friendly MoT Testers'?
Posted 07 April 2015 - 08:28 PM
Yeah that's a fair point, I wasn't aware of an existing thread like that, but I suppose we could start one. I'm sure many of us here have mini friendly MOT testers we use and would recommend. I know of at least two in my area.
Posted 07 April 2015 - 08:36 PM
I know a good one, Your a TMF Team member, could you start a Sticky?
Posted 07 April 2015 - 09:10 PM
I'll discuss the idea with the rest of the TMF team and let you know. ![]()
