This is driving me a bit crazy so any suggestions gratefully received...!
I'm getting a knocking/clicking from the front of my Min ('95 Spi, Jap spec), I think from the off-side front wheel. It only happens once the car's travelled a few miles and stops when you put the brakes on. Release the brakes off and it starts again.
I've taken the car to the garage and they can't see anything wrong or replicate the problem (possibly because their test drives aren't long enough to allow the noise to start!), but they've had the wheels off to replace tyres and say nothing is amiss or falling off.
The knocking only happens when the car is in motion and sounds rotational (like something's going round on the wheel and bashing into something).
I've tried turning on opposite lock to see if it's the CV joints but this doesn't really make a difference - although it gets marginally less bad when turning right - but it always stops when I apply the brakes.
There's no judder in the brakes, but the problem does seem worse if I've used the brakes a lot.
Any suggestions?!
