Mk1 Speedo Surround With Rev Counter.
5 replies to this topic
#1 leaky
leaky
  • 6,890 posts
Posted 10 April 2015 - 10:01 PM
I after one of these if anyone has a link to where I can order one that would be great. Seen a stall at shows selling them but they weren't at brooklands this year.
10464254_10153903412134848_4156058128457
#2 mab01uk
mab01uk
  • 12,549 posts
Posted 11 April 2015 - 07:45 AM
Broadspeed Dashboard
As fitted to Broadspeed Minis from the 1960's. Exact reproduction from the original. For the more observant out there, the graining on the material is correct too.
Made with a larger lip to be cut to size, all you require is the chrome bezel off your original binnacle, and speed mounting brackets.
Dash takes standard clocks and an 80mm hole for the "smiths" taco. Designed to fit MK1 but can easily modified to fit in MK2/3 or 4 mini.
£100.00 (plus P&P)
Scroll down on right:-
http://bmccomps.co.uk/products.php
or register with the MK1 Forum and contact member 1071Bob, who makes them:-
http://mk1-forum.net...&t=9102&p=67765
http://mk1-forum.net...&t=9529&p=71809
Edited by mab01uk, 11 April 2015 - 07:47 AM.
#3 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 11 April 2015 - 10:48 AM
i got mine at L2B about 5 years ago, the same stall is also at beaulieu as well.
it was a very good fit, i had to do a lot of work behind the cowl with cables , mounting and making everything fit.
there was a article in min mag by stephen about fitting one of these, it was about 2-3 months ago.
#4 leaky
leaky
  • 6,890 posts
Posted 19 April 2015 - 10:19 AM
£100.00 (plus P&P)
Are the ones on that link the same ones that bob make? Or are they different companies/people
#5 mab01uk
mab01uk
  • 12,549 posts
Posted 19 April 2015 - 01:12 PM
Not sure....I would contact 1071Bob first as if they are the same, his price may be lower going direct via the Mk1 forum.
#6 leaky
leaky
  • 6,890 posts
Posted 19 April 2015 - 08:09 PM
Nice one I'll give him a message then cheers
