Center Cap Sizing Questions
1 reply to this topic
#1 fourvalleys
fourvalleys
  • 12 posts
Posted 13 April 2015 - 07:13 PM
Hello all -
My mini has 12" Minator wheels that have conspicuously absent center caps. I've been looking to find a set that will work, but I'm a bit stuck.
The center hub bore has an inner diameter of 58mm. However, it does have a noticeably larger inner diameter past the opening. See the photo.
http://i.imgur.com/lpsI2fJ.jpg
Does anybody have suggestions of center caps that might work? I'm not looking for anything fancy, even something flat would work just fine. I just don't want to waste money buying singing that won't work.
#2 mingy
mingy
  • 930 posts
Posted 13 April 2015 - 08:05 PM
Centre caps usually have a lip at the " open end " to stop them flying out , but also they tend to be tapered so as to get a tight fit into the hub hole. I am sure you can still get 58mm caps for certain alloys etc, JBW ( John Brown Wheels ) do centre caps for their range of alloys so it,s worth googling.
You need to fit them from the inside which, means taking each wheel off to fit them ( sorry if you did know that ).
