3Rd Gear Removal
10 replies to this topic
#1 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 14 April 2015 - 11:20 AM
Hi guys,
Stripping down a a gearbox at the moment and have done everything but I am having a nightmare trying to get the 3rd gear off, I have pushed both of the needle springs in and turned the thrust washers but it just won't lift out, I have tried to line the thrust washer up like is should lift out but it's not,
Anybody got any tips? This is the last of the strip down ready for a rebuild next month and I can't seem to get it out
Craig
#2 Spider
  • 15,176 posts
Posted 14 April 2015 - 11:36 AM
I can see right away where your going wrong.
Try holding your tougue on the otherside.
Nah, sounds like you are going about it right, just gotta keep at it and be patient, they are very neat. To get them off, they not only need to line up with the slots, but also be perfectly on centre.
Edited by Moke Spider, 14 April 2015 - 11:37 AM.
#3 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 14 April 2015 - 11:49 AM
Doesn't sound like you're doing anything wrong, they can be a bit fiddly. Generally you need to try and hook it out whilst lining it up correctly.
#4 Fossy313
Fossy313
  • 583 posts
Posted 14 April 2015 - 02:30 PM
Ok guys, can I ask what are the holes for in the side of the 3rd motion gear?? Do I need to line them up with anything? I shall try again tomorrow as it's round my parents garage, I'm just affraid of scratching the main shaft as I'm trying to use two picks/ small screw drivers to push the pins in and a screw driver to turn
#5 69k1100
69k1100
  • 376 posts
Posted 14 April 2015 - 02:47 PM
Unlikely you will scratch it as its hardened, however you shouldn't need to apply too much force.
http://youtu.be/dTXH...uiUv9FCxc96uEBv
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 April 2015 - 03:35 PM
By the sounds of it, it's the second idler you're on about not the 3rd...
The 3rd is the one nearest the end of the shaft which has the bearing on, furthest away from the pinion and main retaining thread. This is held in by one pin and spring...
To remove the 2nd idler, first make sure the 3rd idler is still on the main shaft... you will need to use this for leverage...
Get the idler locking thrust in the position that both the pins are in and the splines on the shaft are lined up with the locking thrust. Place a large flat bladed screwdriver or pry bar, between the 2nd and 3rd idler and apply gentle upward force on the gear by pushing the lever down, while rotating the gear.
The two holes in the cone are for putting the locking ring back in...
http://www.guess-wor...d/mainshaft.htm
#7 Fossy313
Fossy313
  • 583 posts
Posted 14 April 2015 - 06:49 PM
John,
Thanks that sounds like a better plan, it is indeed the 2nd idler, sorry I'm getting the names muddled up. Much appreciated and I will refit the 3rd idler and give it a go.
Shall be ordering your rebuild kit at the end of the month.
Thanks fort he help guys I will let you know how I get on.
#8 Fossy313
Fossy313
  • 583 posts
Posted 14 April 2015 - 07:02 PM
Also 69, thanks that video shows leverage from a vice so it's another way I can try, much appreciated for the help guys
#9 Fossy313
Fossy313
  • 583 posts
Posted 15 April 2015 - 01:04 PM
Just wanted to say thanks mate i put the 3rd gear on and didn't really need any leverage at all just a little help,
That's it all stripped down and cleaned.....I have cleaned the inside of the box and outside with mineral/white spirit(from a compressor spray gun ) and then put compressed air through everything and it's very clean., was wondering what's best to clean the gears and that up, can I use this as well??
Edited by Fossy313, 15 April 2015 - 01:05 PM.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 April 2015 - 01:23 PM
Paraffin or old petrol will do a good job, as will brake cleaner, I have a petroleum distillate in my parts washer which shifts most of the grot. Don't be too fussed about getting them shiny clean, as you'll only do that with a chemical dip or blasting.
#11 Fossy313
Fossy313
  • 583 posts
Posted 15 April 2015 - 07:44 PM
Thanks mate, your tips have been invaluable
