998 A+ Feels Sluggish And Slow Acceleration
5 replies to this topic
#1 webby0121
webby0121
  • 117 posts
Posted 15 April 2015 - 09:29 AM
Hi i have a 998 pretty much stock mini and it feels slow and sluggish off the line and with general acceleration.
Any ideas as to what this could be?
And how to improve it?
Thanks!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,042 posts
  • Name: Neil
Posted 15 April 2015 - 09:49 AM
Basic things first. Service it, plugs, points ( if fitted) air filter, oil and oil filter and fuel filter if fitted. Check the carb dash pot oil level is correct as well. Once fine and everything gapped correctly check the timing.
If it's still sluggish after that then further checks like tappet gaps, checking the carb is opening fully and correctly. Do a compression test as well.
#3 webby0121
webby0121
  • 117 posts
Posted 15 April 2015 - 10:22 AM
Has new plugs, elec ignition, and new oil, also done dash pot, doing timing tomorrow.
 And ill have a look cheers
#4 carbon
carbon
  • 2,590 posts
Posted 15 April 2015 - 07:51 PM
Depending on the year it may have the tall 2.95 final drive fitted.
For getting off the line smartish a 3.44 final drive would help, but won't be so relaxed when cruising at speed and fuel consumption may also increase.
#5 Dr s
Dr s
  • 428 posts
Posted 15 April 2015 - 07:58 PM
3.44? It needs a 3.76 to be sporting :-)
#6 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 15 April 2015 - 08:27 PM
Have you checked that the timing is advancing with RPM? Seized counterweights(cam on driveshaft in dissy) will do this!
