Hs4 Choke Spring
1 reply to this topic
#1 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 15 April 2015 - 06:22 PM
Hi all, bit of a silly question! But I've recently been rebuilding my Waxstat type HS4 and I took the whole choke lever assembly apart to fit a new jet and clean everything up. I have now come to refit everything and I have no idea how the spring on the base goes back on! The larger 'arm' hooks to the post on the carb body itself, but I have no idea where the other part of the spring hooks onto the lever? as there appears to be no hole or obvious cut out under or near the cam lobe, as to where it would sit! Silly question, but I'm completely stuck!
I was just wondering whether anyone had a picture handy of how the spring sits against the body of the carb and hooks into the lever at all! Thanks  :D
#2 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 15 April 2015 - 06:43 PM
Sorry not the best pictures mate but hope it helps a little?
