Clecos
17 replies to this topic
#1 Covert
Covert
  • 526 posts
Posted 15 April 2015 - 10:18 PM
i can see the sense in using these where you cant get clamps to clamp panels together, but when plug welding do you just remove one and plug it up as normal?
Because the hole will be through both panels , ie i use copper on the back to help me plug a hole up i dont need , would you need to do that ? As the most common size as far as i can see it is 1/8 or 3mm , any help appreciated!
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 April 2015 - 10:26 PM
I expect you can plug weld it up as normal. If they only leave a 3mm hole, it's not hard to plug weld it up without the need for copper behind it.
I have just done it with some redundant holes on my new inner wing. Just needs a bit more concentration to avoid blowing through.
But.... I have never used clecos so i'm only surmising
#3 Covert
Covert
  • 526 posts
Posted 15 April 2015 - 10:29 PM
Thanks ben , id rather buy the proper kit , ive just got visions of it blowing through everytime you try and do a plug weld , im torn between buying clecos or really big c clamps to hold my floor to my bulkhead while i weld it up
http://www.ebay.co.u...a90da7#shpCntId
#4 Stu.
Stu.
  • 912 posts
Posted 15 April 2015 - 10:31 PM
If you're using cleco's, yes you'll need to weld up the hole using the method you mention in you're post after completing the plug welds to the area.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 April 2015 - 10:37 PM
I use these
http://www.ebay.co.u...=item5657f4ced7
They are self drilling so i just fit my drill with an appropriate size 1/4 drive socket in an extension bar and buzz them in. You can hold entire sections together in order to trial fit panels etc. Then once they are welded in place, you can pop the drill in reverse, buzz them back out and weld up the small holes left behind.
Far superior to clecos in my opinion as they are not bulky and won't get in the way.
Just my opinion though
Ben
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 April 2015 - 10:38 PM
Plus they can also be reused many many times
Edited by Ben_O, 15 April 2015 - 10:38 PM.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 April 2015 - 10:39 PM
Here is a selection pack which would be more suitable
http://www.ebay.co.u...842848983&rt=nc
#8 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 16 April 2015 - 06:33 AM
I have used clecos in the past but I now use No-mar skinpins from http://www.aetools.co.uk/  the 04-SSL-1/8 ones http://www.aetools.c...-length-433.php
They seem to be better at clamping the two pieces together.
Ger
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,044 posts
  • Name: Neil
Posted 16 April 2015 - 07:21 AM
Ger
5/32 would be better however the nylon base melts so not good from that point of view.
#10 ibrooks
ibrooks
  • 1,017 posts
Posted 16 April 2015 - 10:13 AM
The thing with Clecos and Skin pins is that they aren't really designed to hold panels for welding so whilst they do work for what you are talking about it's a bit of a compromise with the hole being left in both panels that you need to account for when welding.
The original concept was that they would be used where panels are to be riveted to a frame (originally aircraft skins). The panel is held in place with the pins whilst the holes for the rivets are drilled and then it can be removed and the inevitable swarf cleaned from between the panels before the desired paints/sealants/adhesives are applied. The panel is then put back on and held in place with the pins whilst it's riveted on (either pop-rivets or traditional rivets).
Iain
#11 sonikk4
sonikk4
  • 16,044 posts
  • Name: Neil
Posted 16 April 2015 - 11:07 AM
Considering the fact there are a lot of areas where you cannot get clamps in then skin pins or clecos are perfect for the job. Better that than trying to force panels together. And bare in mind if you are using blind fasteners ie Cherry etc you may not get to the area behind. But I digress having a few small holes to weld after is not a big deal
#12 Covert
Covert
  • 526 posts
Posted 16 April 2015 - 11:13 AM
So in your eyes Neil, I would be better using the self tapping screws linked by ben ?
Thanks Mark
#13 sonikk4
sonikk4
  • 16,044 posts
  • Name: Neil
Posted 16 April 2015 - 11:45 AM
Personally the only time I use self tapping screws is for the wings nothing else.
#14 Dr s
Dr s
  • 428 posts
Posted 16 April 2015 - 06:35 PM
I like the clecos and intergrips remember your not going to have a lot of tension in the metal. Blebing in 3mm hole is not hard with the welder
#15 sonikk4
sonikk4
  • 16,044 posts
  • Name: Neil
Posted 16 April 2015 - 06:59 PM
These ones are now my weapon of choice at 5/32nd. Mine are not this brand but very similar
http://www.aetools.c...perated-425.php
