Sizzling Noise Coming From Radiator?
22 replies to this topic
#1 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 05:44 PM
Hi,
I've noticed recently that when I come back from a drive, I hear a water boiling/sizzling noise coming from the engine. I think it's coming from the radiator. I've also noticed that when you put your hand on the passenger's side wing, it's very hot, whereas the driver's side is cold.
Any ideas?
Thanks,
Corey.
#2 Stu.
Stu.
  • 912 posts
Posted 16 April 2015 - 05:52 PM
If your rad is side mounted (as standard) the fan blows the heat through vents in your inner wing which will heat the outer wing so this is normal.
Have you checked your temperature gauge, is it reading normal during driving?
Have you checked the level of your coolant?
Edited by Stu., 16 April 2015 - 05:52 PM.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 16 April 2015 - 05:55 PM
As above is the coolant topped up? (make sure it's not to hot to take off and sprays hot coolant every where)
#4 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 06:03 PM
My temperature gauge isn't accurate I don't think. It takes a while to start up, and when it does it shows the exact same temperature all the time.
If I needed to buy new coolant, will any regular stuff do? Most people try to recommend specialised stuff (Silly question, but always worth asking).
Edited by Corey96Williams, 16 April 2015 - 06:04 PM.
#5 alex-95
alex-95
  • 6,078 posts
Posted 16 April 2015 - 06:09 PM
You'll need the blue stuff, I got mine from halfords, if you don't know what sorts in it at the minute then drain it out, flush it through and fill it with new.
Wheres the gauge sitting at? middle?
#6 Stu.
Stu.
  • 912 posts
Posted 16 April 2015 - 06:16 PM
Yeah as Alex said you just need a decent Antifreeze & Summer coolant, which you dilute with water for the desired freeze range protection (normally a dilution table on the bottle).
My gauge takes a while to come to life too, and normally rises to half way and stays there, which is normal unless your racing the engine a bit in warm weather which pushes the needle a little over half way.
#7 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 06:26 PM
Well, I checked the expansion tank and it looks empty from the outside, but when I took the cap off, it seemed full to the brim. Although, it was slightly orange...
Edited by Corey96Williams, 16 April 2015 - 06:37 PM.
#8 Stu.
Stu.
  • 912 posts
Posted 16 April 2015 - 06:50 PM
Well if the expansion tank is full to the brim, theres nowhere for the water to go when it expands is there. If the tank is under pressure this is why its sizzling. Remove some coolant from the expansion tank so its about half full.
#9 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 06:54 PM
Will it be worth changing the coolant while I'm at it?
#10 Stu.
Stu.
  • 912 posts
Posted 16 April 2015 - 06:59 PM
I suppose you could, do you know how long its been in?
#11 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 07:04 PM
I bought it nearly 3 months ago. All the fluids seemed perfect at the time...
#12 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 16 April 2015 - 07:31 PM
Nobody's said this yet so I will. Your temp gauge does work.
#13 Corey96Williams
Corey96Williams
  • 316 posts
Posted 16 April 2015 - 07:34 PM
Haha, I assumed it did. I just never thought it would be accurate as it's either on fully cold or nearly halfway  :gimme:
#14 Stu.
Stu.
  • 912 posts
Posted 16 April 2015 - 08:09 PM
Quote - My gauge takes a while to come to life too, and normally rises to half way and stays there, which is normal unless your racing the engine a bit in warm weather which pushes the needle a little over half way.
[/quote]
Thought I did mention that fella. Sorry I should have been clearer I guess :)
#15 Spider
  • 15,685 posts
Posted 16 April 2015 - 09:37 PM
If you can hear it sizzling, then I'd say it's running hotter than it should, or the cap may not be sealing as well as it should.
