Sizzling Noise Coming From Radiator?
22 replies to this topic
#16 Dusky
Dusky
  • 5,322 posts
Posted 16 April 2015 - 10:31 PM
Do you hear it sizzeling all the time? Or only when it's turned off?
If it only does it while it's turned off after a run, I'd check for leaks.
#17 Corey96Williams
Corey96Williams
  • 316 posts
Posted 17 April 2015 - 04:29 PM
I can only hear it after I turn the engine off, but I can't hear it over the engine anyway...
#18 Dusky
Dusky
  • 5,322 posts
Posted 17 April 2015 - 06:15 PM
If it appears after a few seconds of turning it off id really check for leaks
#19 Corey96Williams
Corey96Williams
  • 316 posts
Posted 17 April 2015 - 06:18 PM
I've noticed that there is sometimes some very light steam coming from the radiator cap. Perhaps that's slightly loose. I tried taking the cap off and putting it back on firmly in the hope it might fix it  :gimme:
#20 Stu.
Stu.
  • 912 posts
Posted 17 April 2015 - 06:20 PM
Have you removed some coolant from the expansion tank yet?
#21 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 17 April 2015 - 06:40 PM
The seal may have gone or be failing on the rad cap
#22 Corey96Williams
Corey96Williams
  • 316 posts
Posted 18 April 2015 - 03:47 PM
I emptied some fluid from the expansion tank, and I've changed the fluid in the radiator and it's fixed now. I don't know what specifically made it make the noise, but it's fixed :)
#23 Stu.
Stu.
  • 912 posts
Posted 18 April 2015 - 04:08 PM
Well if the expansion tank is full to the brim, theres nowhere for the water to go when it expands is there. If the tank is under pressure this is why its sizzling. Remove some coolant from the expansion tank so its about half full.
I explained why it was happening earlier in the thread (as above).
If its stopped since you've left some expansion room in the tank then thats why its not sizzling anymore.
When coolant gets hot it expands. You need to leave room in the expansion tank to take account of this.
Edited by Stu., 18 April 2015 - 04:09 PM.
