Hello to all
I need some help on this issue:
How can i convert a mini 850 body with these kind of gearbox
to these?
[/URL]">http://
What parts do i need??
Thanks to all
Jorge
Edited by mini eicon, 17 April 2015 - 03:03 PM.
Posted 17 April 2015 - 04:39 PM
Can anybody help please?
Posted 17 April 2015 - 04:42 PM
The first type is the "Magic wand" gear selector, the second is a "remote" gear selector.
I don't have first hand experience of swapping these over, but briefly the rear housing of the gearbox/diff housing is different along with the selector mechanism.
I'm sure someone with more experience will have a detailed idea about what to change.
Phil.
Posted 17 April 2015 - 05:05 PM
You need to change the gearbox from a 'magic wand' type to the later remote shift type. The gearbox casing is different.
Then cut a hole in the tunnel, plate over the original hole and fit a gaiter onto the lever to keep the wet out.
Posted 17 April 2015 - 05:09 PM
Posted 17 April 2015 - 05:14 PM
Posted 17 April 2015 - 05:15 PM
I also want to change the engine to a 1000 or 1300cc engine.
Posted 17 April 2015 - 07:46 PM
Jorge,
Looks like it's an early 850 in pretty good original condition from your top picture?
Posted 17 April 2015 - 08:38 PM
As Phil said, the housings are different between the 2 and would require engine out surgery.
Another possible idea, which may be around, is a remote shifter kit. Way back when they first came out there was a kit available to make gear lever further back, sort of linkage set up.
Is it a 'personal preference' thing or is it because the shifters too far away/floppy?
If its the later, make sure the links, bushes and pivots aren't too worn and then straighten the gear lever at the bend near knob. There's extension bits available but theyre not much help as the lever ends up looking like a pretzal.
Called an "SPQR"
Long and short if you want the gear stick just in front of the handbrake then you'll need a remote gearbox.... also if you're considering changing to a 1300, then you will also need either a cooper S 3 synchro remote gearbox (333 or 190) or a 4 synchro remote otherwise the engine will not fit on the gearbox and the crank will not rotate without taking chunks out of the case.
Posted 17 April 2015 - 09:58 PM
Posted 17 April 2015 - 10:28 PM
As the diff cover and the gearbox casing are matched, in fact you need a complete Cooper gearbox to do the job properly. The Cooper/Cooper 'S' had different gear ratios from the 850 as well.
Posted 17 April 2015 - 10:48 PM
I have fitted a Magic Wand Diff cap to a remote style Gearbox Case, mind you, I did have to machine up the flange faces to get them on the same plain. I also removed the dowels from the case to cap face.
Having done it this way, I don't see that it would be an issue going the other way, however, either be prepared to try a LOT of different caps (not easy to come by these days!) or have the parts machined to improve fit. Without doing this, at the very least, expect oil leaks - more so than 'normal'.
Posted 17 April 2015 - 11:03 PM
But if the OP is building a Mk.1 Cooper he needs the Cooper gear set as well, so might as well look for a complete Cooper gearbox.
Posted 17 April 2015 - 11:04 PM
