Can You Spray The Inside Of The Petrol Tank With A Rust Inhibitor?
7 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 17 April 2015 - 03:33 PM
As the subject says - can you do it and what would you use?
Ta
Rod
#2 MrBounce
MrBounce
  • 2,685 posts
Posted 17 April 2015 - 03:42 PM
It's better to use a deep cleaning product and then seal the tank with a kit such as one from Frost. There's an internal filter in the tank - it's best to remove this first otherwise you'll be stuck with a sealed filter...
#3 Spider
  • 15,684 posts
Posted 17 April 2015 - 10:01 PM
+1.
I would think anything you'd spray in the tank would wash off with the fuel.
POR15 also have a great tank sealing kit.
#4 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 17 April 2015 - 10:16 PM
The filter that is about 2" away from the walls of the tank?  if you manage to get paint on that, you're doing it wrong :lol:
I used the Por kit (3 stage) from Frost.  Worked a treat.  All details in my build thread.
#5 MrBounce
MrBounce
  • 2,685 posts
Posted 18 April 2015 - 06:01 AM
It's in the middle of a baffle plate in a van tank and thus easy to cover (see my build thread for my monumental balls up!). Not sure on the saloon ones though, but as you have to rotate the tank anyway to cover the inside I would be careful as it can get EVERYWHERE!
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 April 2015 - 01:03 PM
If you are only dealing with surface rust, clean the tank and keep it full of gas to prevent corrosion in the future.  Save the lining/coating kits for fixing leaks and saving RH (or very early) tanks.
Interesting timing of your question.  See the thread linked below currently running on MM.
http://www.minimania...gas_tank_sealer
Edited by dklawson, 18 April 2015 - 01:03 PM.
#7 rodandtom
rodandtom
  • 998 posts
Posted 18 April 2015 - 01:48 PM
I've now welded the neck of my tank so the question is more about how to treat the weld on the inside of the tank to help stop it rusting. I would imagine just a lining of POR around the inside of the neck should be fine. It's not like it will be in permanent contact with petrol so should last ok I reckon.
Rod
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 April 2015 - 05:03 PM
Obviously this is your choice and your tank, however, I don't anticipate that you need to do anything special to protect the weld.  I know that in some instances welded areas do tend to rust preferentially compared to surrounding metal but this will be inside a gas tank with limited exposure to water vapor.  It is extremely unlikely to rust through or cause you other problems if left uncoated.
