Yellow Pipe?
Posted 17 April 2015 - 08:18 PM
I have a thin yellow tube not connected to anything on my spi.
It seems like a brown pipe comes from under the air filter, it then joins to the yellow one that lies near the top of the air filter but isn't connected.
The car seems to run ok.
Any ideas??
Posted 17 April 2015 - 08:24 PM
it should connect to under the filter (beside the brown (which is actually red)) and on the top of the filter.
Posted 17 April 2015 - 08:27 PM
That's ace. Thanks
Posted 18 April 2015 - 07:25 PM
I've only had the car since sept.
Why would it have been blocked off??
Posted 18 April 2015 - 08:14 PM
not sure why it has been blocked of. I can't remember correctly, but I think the yellow one is used to pull air towards the air temp sensor and the red pipe uses a vacuum from the inlet manifold to open a flap to allow the air for the yellow pipe to get to the temp sensor. I am not sure how important all this really is.
Ideally with the standard filter in place you should have this pipe connected.
Though cars fitted with a after market filter, remove the yellow pipe and block the end pif the red line.
Posted 19 April 2015 - 05:42 AM
I'll get a new pipe and see what changes it makes.
Thanks guys
Nic
Posted 19 April 2015 - 07:14 AM
The yellow pipe just operates a flap in the air box intake pipe. It's so that when the car is cold, the flap closes and air is drawn in from underneath that pipe, which sits on a metal bracket attached to the exhaust manifold and heats the air. Once the engine warms up, the flap closes and air enters via the front of the pipe as normal.
It will have neglible effect on running in relation to warm / cold air, however if the yellow pipe was lying disconnected it could provide a vacuum leak when the engine is cold and vacuum is acting on the pipe. This is likely why the pipe end is blocked off.
