Good afternoon all
Hope everyone is enjoying this fab weather!!!
Anyway, to the matter in hand, as the title suggests, I have a real problem with the lower offside radius arm bracket thread in the rear subframe.
I bought the subframe donkeys years ago at Stanfoord Hall, it was second hand, but a genuine item.
During some recent freshening up of my Mini in the vain hope of getting it on the road this year, I had to replace the perished radius arm bearing seals (only 2 years old).
When re-attaching the radius arm bracket the lower bolt wouldn't tighten up. Now I replaced this bolt some years ago and helicoiled the threaded hole as the thread had stripped. The only helicoil I could get hold of at the time was a metric one, slightly larger than the 1/4" UNF (M8 I think).
The problem I now have is this thread has gone and it looks like the helicoil has come loose or broken up so the resulting hole is too large to do anything more with. In fact a 5/16" UNF is a rattling good fit in the hole .
I'm planning to whip the subframe out over the next couple of weekends and looked at the cost of a new genuine 'frame...£400!!
The only option I can think of is to get a workshop to drill out the hole large enough then weld in a 1/4" UNF nut, grind back and then I can repaint the 'frame....unless anyone has an alternative???
Cheers muchly,
Steve.
