Earth Getting Hot
Best Answer Gerbil367 , 22 April 2015 - 09:07 PM
Ah, thanks mate, I will have a look before getting the credit card out Go to the full post
16 replies to this topic
#1 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 18 April 2015 - 05:41 PM
Hi guys, strange thing occurred yesterday. The point i have used on my inner wing bracket to earth my spot/fogs and the heater got hot yesterday while out for a quick run. I disconnect the battery each night, so when I connected it again today (just sat still) the bracket at the earth heated up again - tested it for any circuit but no current going through it - any ideas why it would do this? Should I disconnect each thing from power and see if it continues? Appreciate any advice!
#2 sledgehammer
sledgehammer
  • 3,108 posts
Posted 18 April 2015 - 05:52 PM
Global warming apparently
or
fit another earth cable
make sure connection to body is good clean steel
find a  nice place clear of rust
resistance = heat
ps - are you sure the heater is earthed on the inner wing ?
mine is the other side of the  bulk head
Edited by sledgehammer, 18 April 2015 - 05:58 PM.
#3 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 18 April 2015 - 06:31 PM
Cheers Slegehammer, Mine didnt have a heater when i got it, fitted it last year and used a clean point on inner wing at the time - it has been fine until yesterday, everything works ok, but know it cant be good especially with long trip to L2B next month. Will try a new cable and clean the earth again.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 April 2015 - 08:04 PM
You have a connection where the heat is with a high resistance as pointed out by sledgehammer above, strip and clean the contact points and do the same with the earth  strap in the engine bay
#5 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 18 April 2015 - 08:06 PM
Roger dodge, will do
#6 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 20 April 2015 - 03:53 PM
OK - after cleaning up all my earth strap points, earthing points on the body work etc, I finally found it wasn't that causing the heat!!!  Problem is I don't know what the part called that is that is heating up!!!
Its the gold corrugated cardboard looking thing!!! What is it and should it be hot just when I connect the battery up??  Can anyone see something wrong?
#7 Alex_B
Alex_B
  • 4,573 posts
Posted 20 April 2015 - 04:43 PM
Thats the dim/dip resistor, fitted to satisfy some euro reg that never actually came into force so can be removed with no ill effects. I cannot speak for how it operates and whether it would be getting hot with nothing switched on, I suspect not. Or what you need to do to remove it as it does need some wiring mods but I don't know them off the top of my head. There are threads on it and how to remove it however.
#8 beakerthemuppet2
beakerthemuppet2
  • 39 posts
Posted 20 April 2015 - 04:45 PM
thats a power resistor... dont have one on my mini but a mate of mine has one, honestly i dont know what it is for.
we use them at work on occasion. they are resistors that operate at high current. and are only slightly resistive (often between 1-15 ohm) and when they get a decent amount of current passing through them they heat up, hence the corrugated fins to aid cooling (once got one so hot that the wires de-soldered :shy: ). so this kinda component is expected to heat up within reason.
as i said i dont know what is is used for in the car. if you have a multimeter or voltage tester maybie try switching on different things and seeing if a voltage appears at the terminals?
#9 beakerthemuppet2
beakerthemuppet2
  • 39 posts
ah beaten to the draw! :P
#10 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 20 April 2015 - 06:47 PM
Thanks guys, thing gets hot as soon as i reconnect the battery and nothing switched on! Oh Bu**er! Im crap with electrics too . Guess I best break out the multimeter and start probing!!!
#11 sledgehammer
sledgehammer
  • 3,108 posts
Posted 20 April 2015 - 08:37 PM
this may help -
http://www.theminifo...t-problem-help/
#12 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 20 April 2015 - 09:20 PM
Thanks Sledgehammer, I will take a look tomorrow to see if I can figure it - not great with electrics but if i take my time, who knows
#13 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 21 April 2015 - 10:40 AM
My full beam doesnt seem to work now when I push the indicator stalk forward - could this be where the issue causing the heating has been?  Works fine if I pull back to flash only.
So going by the attached thread by Sledgehammer, I can bypass the bulkhead resisitor just with a bridging wire/connector in the pink relay under the dash?  After that if the full beam still doesnt work, probably an issue with the indicator stalk?  Sorry - I did say Im crap with electrics!!!!
#14 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 21 April 2015 - 10:44 AM
Scrub that!  Im removing the relay and bridging the points located on the connector - Right?  And I repeat, CRAP at electrics!!!!
#15 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 22 April 2015 - 02:30 PM
Thanks guys. With regards the high beam issue,  I traced the blue/white wire back and there were no problems in the wiring or bullet connectors, but I cleaned up the connectors in the switch on the stalk, did the wiring mod and lights worked, no heating :D .  Of course it wasn't that simple!!! I then tested indicators and they didn't work!!  As I had the ignition cowling off, I jiggled the indictor a little and they started working so I guess my light/indicator stalk/switch is a bit faulty.
I did find a weird bodge when I took the dim/dip relay off - the brown wire had a break in it and had just been joined together wire to wire with no insulation or tape covering the bare wires!!  Done a quick fix for now until I get another connector to make it safe.  Third wiring bodge found so far!!
Thanks again for the guidance.  Im still crap at electrics though :D  :D :D
