Driveshafts
12 replies to this topic
#1 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 18 April 2015 - 09:02 PM
Hi I have a single seater racing car that I am currently working on, when I have finished the rebuild on the car I'm going to look for a classic mini to restore. The car is a Global GT Light, it is being converted to run a turbocharged fireblade engine producing around 260hp.Anyway I need some advice from some mini owners as the driveshaft's used on the global are from a classic mini. I know someone who can make the actual drive shafts out of something strong enough to take the abuse I want to put through them but I'm unsure of what the difference between the joints are on the hub side anyone got any pointers so I can work out wich ones too order
thanks for any advice
#2 nicklouse
  • 18,697 posts
Posted 18 April 2015 - 09:05 PM
Inboard there are two spine patterns and out board there is just one.
So pot joint or hardy spicer/cross type?
#3 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 18 April 2015 - 09:14 PM
Check this out:
http://www.minispare...px|Back to shop
#4 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 18 April 2015 - 09:16 PM
pot joint type, the driveshaft's are 287mm in length if that helps I had a look on mini spares but can't work out wich one I need to order on the hub side
thanks for the link Leon but my budget doesn't quite stretch that far I think I can build a set just as strong for less than that if I can work out wich hub joint to order
Edited by GlobalGT, 18 April 2015 - 09:25 PM.
#5 nicklouse
  • 18,697 posts
Posted 18 April 2015 - 09:29 PM
Ok so you have two drive shafts of the same length?
Minis have unequal length shafts. So it will be a custom order.
#6 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 18 April 2015 - 09:38 PM
yes nick im using two equal length shafts on the car. the shafts I can get made easy enough, i'm presuming the pot joints are a one size fits all job so i'm just stuck with the hub side as i'm unsure of the differences between them
#7 nicklouse
  • 18,697 posts
Posted 18 April 2015 - 09:40 PM
Hub side all the same if using Mini CVs. Even the bigger CVs have the same spline patten as far as I am aware.
So not really sure what you are asking as you know the length and the spline patterns you are using.
#8 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 18 April 2015 - 09:47 PM
I have been told the hub side of the cv joints are different for the 850-998 and the 1275s I'm trying to work out which ones i'm using and what the difference is
#9 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 18 April 2015 - 11:08 PM
With the outer ends (hub) The differences are in the actual cv joint, the drum brake models have a small shaft where it goes through hub (and doesn't hold wheel on), the disc bracket ones are bigger and hold the hub and wheel on. Both the drum and disc versions have the same spline set up where the actual axle fits in.
On to inner ends theres 2 types of splined sections, one is similar to outer, with a clipped on cv (pot) joint, the other is a sliding shaft with either a proper uni joint or a rubber cross u bolted in. (Rubbish in high HP car)
Possibly there's some one near you that may have some of both examples fo you to look at.
#10 nicklouse
  • 18,697 posts
Posted 19 April 2015 - 08:08 AM
As above Only difference is the CV the drive shaft is the same.
I would guess you have these.
#11 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 19 April 2015 - 09:08 AM
Thanks Nick and Peter I think I have it worked out now I will order the ones in your link on Monday Nick as I'm certain there the ones on the car now thanks for your help guys now I just need to work out what the best pads for it will be the rears are mini front so I may ask you guys for some help with that as well  :shy: thank you for your help so far
#12 nicklouse
  • 18,697 posts
Posted 19 April 2015 - 09:11 AM
Pads depends on useage. In my GTM (Mini engine in the rear) hillclimb car I just had standard front pads both ends as I wanted something that would work from cold. And in hillclimbing the brakes don't get that hot.
#13 GlobalGT
GlobalGT
    Just On Tickover
  • 6 posts
Posted 19 April 2015 - 09:25 AM
I have green stuff pads at the moment but I cant get them to work the car is mainly used for the quarter mile and hopefully Brighton speed trials if I can get it through scrutineering
