Weard Crank Lockup Problem
Posted 19 April 2015 - 10:49 AM
However, If I leave the locating rings out between the block and cap I can torque it without problems. It looks like I cant push these rings deep enouh? Any ideas?
Posted 19 April 2015 - 10:51 AM
Posted 19 April 2015 - 10:53 AM
Posted 19 April 2015 - 10:56 AM
Edited by Dusky, 19 April 2015 - 10:56 AM.
Posted 19 April 2015 - 12:51 PM
Posted 19 April 2015 - 01:56 PM
Are the caps on the right order? Are the bearing shells the correct size? Are they correctly seated? Are the caps the right way around?
does the crank jam? You haven't made this explicitly clear, first you say t locks up but then you talk about not being able to seat the dowels properly, so which is it?
Building an engine isn't as easy as ripping it apart then slapping it back together. Certain machining operations were carried out with parts of the block assembled, the caps were line bored assembled, so they have a specific order and must be the right way around.
Posted 19 April 2015 - 02:31 PM
Posted 19 April 2015 - 02:41 PM
OK... you say the caps are on the right way. However, as 69k1100 asked, are they on in the right order? Did you mark the bearing caps for position before removing them the first time?
Did you measure the crank journals before placing it on the shells? Did you measure the bearing shell thickness to confirm they are all the same?
Line boring is not typically required on a regular rebuild of a street engine. It is an expensive process that is dictated for certain conditions but it isn't automatically part of a rebuild.
Posted 19 April 2015 - 02:52 PM
Posted 19 April 2015 - 03:29 PM
I do think everything came from the same engine, bought it in bits though.
https://www.dropbox....172047.jpg?dl=0
https://www.dropbox....172052.jpg?dl=0
Posted 19 April 2015 - 04:00 PM
Posted 19 April 2015 - 04:44 PM
Hmmmmm. bit of a clue here i think. NO?
Posted 19 April 2015 - 05:03 PM
What should the young padewan do when it wasnt from the same engine? Line bore?
Strange thing is that I can turn it fine when I leave those dowels out on the 'conflicting' cap
Posted 19 April 2015 - 05:15 PM
The dowels are there for a reason, but make sure they are not misshaped..
then check that they are the right caps...
Also now you've had a play check the shells for witness marks/rubs.
What I would do is measure the main bearing for ovality with a micrometer and if you have access, put the crank between two centres and rotate it with a DTI on all 3 mains... check for straightness and run-out.
Posted 19 April 2015 - 05:58 PM
