Remove Rust From Just 4 Simple Steps;
Step 1:
In a container, pour a sufficient amount of EVAPO-RUST to completely cover the rusted object
Step 2:
Immerse the rusty object in the solution and leave it for 10 minutes for light rust or up to overnight for extremely heavy rust.
Step 3:
When finished, rinse item with water. If deep rust remains in pits, re-immerse item until all the rust is gone. Un-rusted metal will not be affected.
NOTE: This stage is VERY important in getting the best results
Step 4:
To prevent flash rusting, dip the item back into solution. Then allow item to air dry. This will prevent rust for up to two weeks.
EVAPO-RUST is an amazing rust eliminator!
A product of extensive research, EVAPO RUST rust remover is an environmentally-safe water-based product that removes rust in minutes, without scrubbing.
It's so easy to use, anyone can restore their rusted tools, auto parts, even firearms to like-new condition.
• Removes even heavy rust completely and is non-toxic, non-corrosive and safe on skin.
• No fumes or bad odors, non-flammable, no VOC's
• Biodegradable, water soluble
• Requires no special equipment
• Will not harm unrusted steel, safe on other metals
• Will not affect plastic, PVC, Viton and most paints
• It's very easy to use EvapoRust to fix all of your rust problems.
Available in 2 sizes:
• US Quart (946ml) - ONLY £7.99
• US Gallon (3.78L) - ONLY £15.99
One gallon de-rusts up to 300 lbs. of steel.
