Heater Motor Repair / Alternative
16 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 April 2015 - 06:37 PM
my heater motor doesn't work, i have tried it over battery and it spins if i give it  a little push. I have tried to pub it up and that has helped.
Haynes says that these cannot be rebuilt. Surely they can...
Has any one successfully repaired one?
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 April 2015 - 07:28 PM
jeeso, just checked the prices for these (part number JGC100110) 300 pounds.
is there an alternative?
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 25 April 2015 - 07:53 PM
jeeso, just checked the prices for these (part number JGC100110) 300 pounds. [/size]
is there an alternative? [/size]
take a look on eBay, I have got a replacement for my Capri one for £40 as opposed to £165 for a genuine Bosch one. It is identical in size and works perfectly.
Or get a decent second hand one......
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 April 2015 - 07:54 PM
Can't find any on ebay at all.
i have posted a wanted ad on here and on a local forum.
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 25 April 2015 - 07:58 PM
Have you tried the serial number? The one I got was listed for a Merc. I am not sure if the mini ones (Smiths?) were used in anything else or not but I bet they were.
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 April 2015 - 08:00 PM
yip, part number JGC100110
#7 Ethel
  • 26,074 posts
Posted 25 April 2015 - 08:11 PM
Does it wobble about, suggesting the bearings are shot? If not it might just be the brushes. If you can get to them ebay has plenty to choose from and, being carbon, they're easy to modify.
#8 Ethel
  • 26,074 posts
Posted 25 April 2015 - 08:16 PM
http://www.ebay.co.u...=item258c7434f0
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 April 2015 - 08:19 PM
I should have been more clear, this is the blower i have (spi):
Screen%20Shot%202015-04-25%20at%2021.55.
I guess the motor you posted is for an earlier mini.
#10 Ethel
  • 26,074 posts
Posted 25 April 2015 - 08:27 PM
I never knew the changed, new fangled   injection cars  >_<
At least it'll be easier to find a single header, As Clive says, it's quite likely it's not unique to Min's - worth trying a google images search with that piccy, or check out Rover cars of the same era?
#11 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 25 April 2015 - 08:42 PM
It's also worth trying to get the motor out, the motor itself may well have a prt number you can track down and it's bound to be cheaper than the whole unit.
#12 maximas
maximas
  • 108 posts
Posted 25 April 2015 - 08:55 PM
Had to replace mine in January..couldn't get a new one anywhere....you can take it out in 20 mins...I got mine off eBay for a tenner...they do come up...mine would sometimes work...then nothing for ages...then work again...I was also told to forget trying to mend it...summers here anyway..just be patient ..one will pop up...
#13 fenghuang
fenghuang
  • 796 posts
Posted 26 April 2015 - 06:03 AM
I have just partly stripped a heater motor that wasn't spinning at all, cleaned it, and now it spins. I can't say it spins as fast as a new one but ...
From memory it's just a few screws, a couple of clips, and the impellers are push fit. If you're any good at figuring how things come apart it's very simple.
I think I needed a squirt of Plusgas somewhere along the line, but that was it. No specialist tools.
The hardest bit was getting the plastic impellers off the motor shaft. It took a lot of force and without thinking about how you're pulling it, I guess it would be relatively easy to distort them. But it's simple to do with a little thought.
The hinged clips that keep the armature in took quite a bit of force to push back into place.
It's worth noting which impeller goes on which end of the spindle, which wire connects to which terminal and which way round the armature goes as it would be relatively ease to get these reversed.
An alternative I've considered, is making one.
I reckon a couple of decent axial cooling fans for computers would do the job, and there are cheap matrices on eBay. It wouldn't be difficult to fold up a box out of sheet aluminium. (I think I find a "How to" in the Car Builder Solutions catalog, though I can't see it on my phone right now. It's really just a box and you could easily modify the Mini heater casing to take different fans. (Just make sure they're 12v)
http://www.carbuilde...tions-catalogue
Hope that helps.
Edited by fenghuang, 26 April 2015 - 06:12 AM.
#14 MikeRotherham
MikeRotherham
  • 987 posts
Posted 27 April 2015 - 06:33 PM
There is a gentleman by the name of Ashley Hinton that advertises on Ebay.
His company manufactures motors for old Smiths heater motors (amongst other things) for various classic cars. Could he perhaps help you with regard to replacing the motor in your heater?
#15 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 April 2015 - 10:31 AM
yip
I will refit it all without the fan, I had too buy a new matrix also.
As you say the summer is here, and i have a heated screen should i need to demise it.
I will keep my eye pealed for cheap one.
