Background info : 91 roundnose with an SPI rear loom for the fuel pump wiring joined up to a normal carb loom for the rest. This has been left mostly standard apart from adding an airhorn + its relay, and a rad fan + its relay. + a safety device and its relay.
The 4 cables coming from the ignition switch always used to get warm - to the degree the black connector block melted so a new one was added ( this was before i realised without solving the issue it will just return again!). So now it has : Switch - wires -bullet connectors - wires - black connector - rest of loom.
Now, since the micra conversion we have added the micra loom to the above list - this is running through a single 10A blade fuse running off its own fuse box (im not sure if this is linked to the main fuse box in any way). - this in itself has been no trouble at all apart from blowing the fuse every the car hits the rev limiter - but for now i can deal with that.
My issue is the white wire coming from the back of the ignition switch is now getting so hot it melted its covering and has started to melt the bullet connector and its clear rubber case. The 3 other cables also coming from the switch are also getting hot but im not sure if its just spreading from the white one.
Help! I havnt had a chance to trace the white cable back yet but im going to replace the junk switch and cabling in favour of a new one but i know without solving the issue this cable may well melt too. Any ideas what it could be?
Ive read up about shorting and overloading - the wire doesnt take forever to warm up but it certainly isnt instant - i can keep my hand on it for about 2 mins before it burns!
any ideas gang? Nelly is now my daily and im stuck without her!
