Mpi Steering Wheel
3 replies to this topic
#1 mini stephen
mini stephen
  • 138 posts
  • Local Club: unkown
Posted 26 April 2015 - 01:27 PM
hi all bought an mpi steering wheel for my 92 mini obviously doesn fit as they had dif rack wondering if i can just change the steering colum or do i have to change all ignition barrel and all or is it possible to change just the shaft the steering wheel bolts to
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 26 April 2015 - 01:39 PM
The column(inner and outer), wheel, ignition barrel is different, as is the wiring harness as the airbag is ECU controlled iirc
#3 mini stephen
mini stephen
  • 138 posts
Posted 26 April 2015 - 03:10 PM
i thought a might have got away with just changin the center bar as i only want it for looks dont want it to function
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 26 April 2015 - 03:56 PM
You may get away with making custom column bushes and doing it that way
