Electric Fuel Pump Woes
Best Answer surfblue63 , 27 April 2015 - 07:45 PM
This pump would be suitable for what you need.
http://www.minispare...ssic/SS502.aspx
Go to the full post
7 replies to this topic
#1 NateDogg2909
NateDogg2909
  • 188 posts
  • Local Club: NottsAboutMinis
Posted 27 April 2015 - 07:22 PM
Hi all,
Im rebuilding my 998 to hopefully be some what of a small bore missile and have read back to a issue of the mini mag detailing the know how on types of electric pumps but I still fall short in knowing the best option.
Spec is as follows
998+80
Head - Ported and polished with 1098 valves fitted 1.3:1 roller rockers
Keith Calvers RE13OT cam (somewhere around the 266 profile I believe)
HIF38 for now, possibility in the long term of twin HS2s
keeping the standard ratio box and diff for now.
​I get the difference between interrupter and solid state for the facet pumps but which one will work best is my issue.
Cheers for any help.
Nate
#2 nicklouse
  • 18,696 posts
Posted 27 April 2015 - 07:38 PM
Personally a filter king filter/pressure regulator up front and any pump in the rear.
#3 NateDogg2909
NateDogg2909
  • 188 posts
Posted 27 April 2015 - 07:40 PM
Sorry should of been a little more specific.
Facet rate their pumps in siver/gold etc, its that im struggling with. Also to add I understand the filter requirement and regulator bit too.
#4 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 27 April 2015 - 07:45 PM   Best Answer
Edited by surfblue63, 27 April 2015 - 07:47 PM.
#5 NateDogg2909
NateDogg2909
  • 188 posts
Posted 27 April 2015 - 08:41 PM
Cheers for that. Is the user name anything relation to giltbrook surf blue by any chance?
#6 nicklouse
  • 18,696 posts
Posted 27 April 2015 - 09:43 PM
That pump still really needs a regulator. The SU carb does not really like more than 3 psi.
#7 surfblue63
surfblue63
  • 2,539 posts
Posted 27 April 2015 - 10:38 PM
No.
I used to own a 1963 Surf Blue Austin Mini.
#8 Ethel
  • 26,067 posts
Posted 28 April 2015 - 12:13 AM
This is true, or at the very least buy the pump from a Mini specialist or specify you want a 3psi version for an SU. If you buy a regulator it'll need setting, you'd also be better off with a pump at a higher pressure so it will always be reduced by the regulator's pressure setting.
