Is It Worth Removing Inner Wings
8 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 27 April 2015 - 10:56 PM
As it says really run a high spec 1380 just wondered is it worth it and am I right in thinking it's mostly done because engine bay heat
#2 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 27 April 2015 - 11:16 PM
You could fit louvers in the bonnet father than such a drastic measure. Wouldn't it make it all floppy and weak.
#3 Tupers
Tupers
  • 4,156 posts
Posted 27 April 2015 - 11:34 PM
It's not normally done unless the car's using a fibreglass front end and in that case it is normally for weight reduction.
The grill opening on a Mini if gigantic compared to most vehicles and gets more than enough air through it.
If you are concerned about over heating you would be better off buying as decent multi core radiator and an auxiliary electric fan. It's amazing how many people fork out for a high spec engine and then stick it back in with a 20 year old + radiator that's full of rust deposits and seem amazed when it overheats.
#4 Furyan
Furyan
  • 174 posts
Posted 28 April 2015 - 02:45 AM
I would  leave them in. Shame to cut up mini when its not really necessary. MOT man might not like it, you will have to strengthen it with brace bars.Think ahead when its time to sell it on, it could effect its value to some people.
Edited by Furyan, 28 April 2015 - 02:46 AM.
#5 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 28 April 2015 - 06:29 AM
Nope, not necessary at all.
#6 minilee94
minilee94
  • 3,523 posts
Posted 28 April 2015 - 07:36 AM
Okay nice one people thanks I didn't really want to cut it that why thought I'd ask and I already have a alloy rad just didn't know if it would still get too hot but my plan is to have the rear of the bonnet slightly raised too
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 28 April 2015 - 07:40 AM
You won't need to do that either, I'd just fit an aux. fan to the inner wing for traffic and it'll be fine.
#8 Ethel
  • 26,073 posts
Posted 28 April 2015 - 08:01 AM
Counter productive if you have a side radiator. The engine bay serves as a dam for the air, you'd be diverting some of it from going through the radiator and lowering the pressure and thus density and heat carrying capabilities. If you were to do anything, I'd experiment with some vents to reduce the pressure under the outer wings, still likely to be of negligible benefit at Mini speeds.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 28 April 2015 - 08:10 AM
You could consider an oil cooler, but it must be fitted with a thermostat.
Cool oil which is too cool is as bad as too hot
