Removing Rust From Wheel Nuts.
11 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 April 2015 - 09:42 PM
I have a nice set of minilite wheels, but the sleeved nuts really let them down. They have been on the car 2 years and have started to rust.
How can I remove this rust? (I was thinking chemically) And then how can i keep it at bay?
#2 nicklouse
  • 18,697 posts
Posted 28 April 2015 - 10:36 PM
It depends.
Chromed?
Find a proper chromer and gave them stripped. Copper plated and then chromed. Instead of flash chrominance ghost does not last.
#3 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 April 2015 - 06:51 PM
they are not currently chromed.
Could be an option
Though, I am not sure how cost effective that would be (though i have no idea on the cost).
#4 spiguy
spiguy
  • 1,537 posts
Posted 29 April 2015 - 07:09 PM
I had chromed ones that rusted. I have a sand blaster at work, so just blasted them and painted them with steel wheels type paint. Doesn't last if you are taking the wheels on and off, but even at that it lasted a good few weeks of wet weather before some little brown bits appeared again on the edges where the wheel wrench had damaged the paint. I just used a brush and wicked a drip or two of paint back on them when I could be bothered. Made them look alot better, but a bit of hassle in fairness. Lucky for me my wheel nuts are only about £16 a set so I can renew them every couple of years if they get scabby.
#5 Richie83
Richie83
  • 1,495 posts
Posted 29 April 2015 - 07:16 PM
Could soak them in coke, worked for my chrome surprisingly well (and scarily). Follow this up with a quick sand down, clean up and then spray silver?
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 29 April 2015 - 07:33 PM
Overnight in Bilthamber Deox c and they will be rust free.
#7 humph
humph
    How bad can it Be?
  • 1,108 posts
Posted 29 April 2015 - 07:40 PM
This is my choice, brilliant stuff.
Alternatively Practical classics did a DIY rust removal article (September 2014) trying various household substances for rust removal; Cola, Potato, Cillit Bang, Oxalic Acid, Vinegar, & Molasses.  In their test items were submerged in the substances for a week, vinegar (undiluted)
or Blackstrap mollasses (1 part molasses to 9 parts water) worked best to remove heavy corrosion. Remove grease and oil from parts and soak in a container with a fitted lid. Worth a try given the cost compared to the Deox C.
#8 nicklouse
  • 18,697 posts
Posted 29 April 2015 - 07:55 PM
I gad forgotten about this http://www.theminifo...hl=+frost +auto
But I would pop into your local http://www.mekonomen.se and have a chat. I found mine to be a wealth of info. As they do cater for a lot of petrol heads.
#9 spiguy
spiguy
  • 1,537 posts
Posted 30 April 2015 - 09:05 AM
What about using wheel nut covers? I was going to do this with my 'rusty nuts' before I bought different wheels and so had to get new different nuts anyway :
http://www.ebay.co.u...=item2c7d3c733a
#10 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 30 April 2015 - 07:52 PM
I think I will try one of these rust removers, I guess i can do it every year or so.
The caps are also a good ice, i have a set on my daily, but the minilite wheels also have washers, these too are starting to look a bit shabby.
#11 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 30 April 2015 - 07:55 PM
You can still buy new minilite nuts ...
#12 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 30 April 2015 - 08:03 PM
Yip you sure can, a set will cost around 30 pounds.  I assume they will just start to rust after a year, just like the ones i have.
