Hi,i am currently using tyre size 145/67/r10 and i havent found any in market instead i get 165/70/r10,will they fit on the same rim?
Tyres
brian ruto
, May 02 2015 03:50 PM
3 replies to this topic
Posted 02 May 2015 - 03:50 PM
Posted 02 May 2015 - 05:03 PM
You'll never find 145/67 as that profile figure is wrong. 165 will probably be too wide for a standard rim but you haven't said what you have ...
Posted 02 May 2015 - 06:37 PM
I'm sure what he means to ask is, Is it a 145/60/10 or 145/70/10 or more likely 145/80/10 or something like that. "67" just doesn't cut it!
Posted 02 May 2015 - 07:32 PM
The important thing is the rim width.
If it is an early car with a 3.5" x 10" wheel, then a 145/80 x 10 is necessary. If it is a 4.5", 5" or a maximum of 6" then a 165/70 x 10 is needed.
Just measure the rim width and go from there.
