Pros And Cons
20 replies to this topic
#16 fenghuang
fenghuang
  • 796 posts
Posted 05 May 2015 - 05:16 PM
I don't have my mini to hand (currently getting welding done) but from memory the inlet manifold heater pipe (Minispares 998 St1 Kit) is a different diameter from the possible hoses that could loop through it.
Does anyone know if there's a hose kit that's designed to plumb in the inlet manifold!
#17 fikasteve
fikasteve
  • 126 posts
Posted 05 May 2015 - 05:24 PM
I believe the inlet manifold pipe is 1/2inch diameter. Later cars used larger 5/8inch diameter pipe for the heater hoses.
#18 kyle9832
kyle9832
  • 434 posts
Posted 05 May 2015 - 07:46 PM
Do this to it :P
IMG_20140315_122539_zpsofgugrm_edit_1394
where do you get that chrome one!?
Edited by kyle9832, 05 May 2015 - 07:49 PM.
#19 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 May 2015 - 08:58 PM
You don't really want it in any exisitng hose runs. Tee it into the heater line so it is independant of the heater valve but maybe give it a little bit of a restriction too. You can get size adapting tee pieces that will help.
#20 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 06 May 2015 - 10:04 AM
Do this to it :P
They are the same, one before and one after anodising.
#21 kyle9832
kyle9832
  • 434 posts
Posted 06 May 2015 - 07:33 PM
Do this to it :P
how did you make it! woww
