Lost All Oil In 2 Months, Water Leak Too. Help!
18 replies to this topic
#16 998kid
998kid
  • 473 posts
  • Local Club: Essex Mini Club
Posted 06 May 2015 - 10:34 AM
I've never done a compression test
And trailered /towed as it's at my mums where I have absolutely no tools
#17 Cooperman
  • 23,513 posts
Posted 06 May 2015 - 11:33 AM
The OP said it had no oil. Does he mean 'absolutely no oil', in that the sump was empty, or just not showing on the dipstick? In 1000 miles a 998 could easily use 4 pints as 250 mpp is not excessive if the engine is worn somewhat. So was it driven over 1000 miles without the oil level being checked? With a Mini it should be checked very frequently, especially as the oil will surge on right hand corners and if low will cause loss of oil pressure and thus damaged main & big-end bearings.
The water loss will probably be a hose as it won't just 'run out' if it's a HG failure.
A bit more engineering logic needs applying here, methinks.
#18 998kid
998kid
  • 473 posts
Posted 06 May 2015 - 10:27 PM
I meant it as not showing on the dipstick
I am usually very good in checking oil and fluids but have slipped having a lot going on recently and am now paying for it
It's not a 998 engine though it is a 1330 bill Richards engine
I filled up to just under the max level after doing a filter change and then didn't check it for at maximum 1000 miles. I'd say more like about 600 - 700
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 May 2015 - 08:18 AM
So you may well not have a issue burning oil, just within normal tolerences on usage, be interested in what the comptession check says.
