Hi!
Project rebuild is almost at the end. Getting some parts later ( oil filter to Block pipe and a distributer) later this week. Can i already install the primed oil pump and fit the engine? Or should i wait untill i have the oil pipe? Engine should be fired up around sunday.
Thanks!
When To Install The Oil Pump?
Dusky
, May 06 2015 05:32 AM
4 replies to this topic
Posted 06 May 2015 - 05:32 AM
Posted 06 May 2015 - 04:04 PM
bump?
Posted 06 May 2015 - 04:08 PM
Yes see no reason why not, if the pump is primed then fit the pipe and crank up oil pressure before starting
Posted 06 May 2015 - 06:08 PM
Me neither, but I was a bit affraid of the pump draining back
Posted 06 May 2015 - 06:33 PM
Then prime it later. Easy to do.
Or cover it with cam lube that will not drain back.
