Rev/tacho Query - Could A 12V Motorbike Counter Be Suitable?
10 replies to this topic
#1 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 07:04 AM
Hi Guys,
Electrics not my best subject!
Have seen various rev counters for sale - Smiths being the obvious but expensive choice when your on a budget.
Found a Tacho/Rev for sale - cheap & cheerful - but retro looking - but advertised for a motorcycle.
It says 12v - neg earth......are these clocks so different from car clocks - only cylinders being different in number really!
Sorry if this is a totally ignorant post!
Si
#2 nicklouse
  • 18,998 posts
Posted 06 May 2015 - 07:12 AM
No such thing as an ignorant question.
But without specifics the answer can only be some will some will not.
If for a 4 cylinder engine then it could work as long as the input trigger system is the same as the engine you have (ignition system).
Classic Mini takes the input from the coil so get 4 triggers per revolution.
#3 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 07:21 AM
OK makes sense - so I really need more info from the supplier of the rev counter as to what the counter is calibrated for? i.e. 2,4 cylinders etc...
#4 nicklouse
  • 18,998 posts
Posted 06 May 2015 - 07:48 AM
yep and also i would post a link so people can see which one it is and they may have tried it already etc...
#5 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 07:54 AM
Ha!....made in China special off Ebay!
LED RPM Tachometer Speedometer Odometer Motorcycle Rev Counter Tach Gauge Meter
Less than £10 delivered so was gonna give it a go!
Thanks for your help!
Edited by Bradshaw-s, 06 May 2015 - 07:54 AM.
#6 Ethel
  • 26,580 posts
Posted 06 May 2015 - 08:29 AM
Sounds like it'll do something, as it mentions a "contacts signal". Expect it's for bikes as it has 0-13k scale.
If it's for a 2 stroke twin it should work, a single pot should read double, but use use all of the scale.
#7 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 10:03 AM
Thanks Guys!
Cant go wrong for £8.99 delivered lol!
Will give it a go
Si
#8 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 06 May 2015 - 10:42 AM
Famous last words :)
#9 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 11:10 AM
:o)
#10 mcduff2
mcduff2
  • 12 posts
  • Local Club: West Cumbria Motorsports club
Posted 06 May 2015 - 04:19 PM
Motorbike ignition systems often use the 'wasted spark' system where there is a spark on each engine revolution which is twice the number of sparks you will have on the mini, you will have to take this into account when selecting the number of cylinders on the selector switch - that's assuming there is one. So to get the correct reading you will have to select a 2 cylinder application.
Select single cylinder and you can tell every one your car revs to 12,000+ RPM  :D
#11 Bradshaw-s
Bradshaw-s
  • 141 posts
Posted 06 May 2015 - 04:37 PM
Ha!
998cc are revvy little things! ;D
