Cleaning Silicone Hoses
Posted 06 May 2015 - 06:53 PM
Anybody know how I can remove this without damaging the hose finish itself. I don't want a stupid looking white logo on the black hoses I've ordered. There's a reason I ordered black, so it doesn't look daft
Posted 06 May 2015 - 07:09 PM
Best to ask Minispares?
Or see if they do logoless versions?
Posted 06 May 2015 - 07:26 PM
Posted 06 May 2015 - 07:34 PM
Posted 06 May 2015 - 07:42 PM
Acetone is the best cleaner for cured silicone. It also does a pretty good job of removing most pigments. Next best would be brake and clutch cleaner, not sure how that would be at removing the pigment but it wont damage the silicone.
Andy
Posted 06 May 2015 - 07:48 PM
to be honest, I would not try to remove it, as you could damaged the strength of the stuff. If that does not bother you, try a strong de-greaser.
Posted 06 May 2015 - 08:26 PM
Also, someone had used acetone and it left a full patch where the logo once was. I'd be ok with that but apparently acetone is too strong for silicone hoses and can cause damage.
Looks like I'll probably be fitting the old rubber ones to my new engine and sending these back.
Why anyone would want logos all over the black hoses is beyond me. If I wanted crap like that all over my engine bay I would've gone full chav and ordered blue ones
Posted 06 May 2015 - 08:35 PM
samco do a classic range with an embossed samco logo which isn't in your face
http://www.demon-twe...licone-hose-kit
Posted 06 May 2015 - 08:43 PM
Thanks for the link, they don't offer the correct kit for my car. Once again another supplier that thinks rover only made injection minis. Could order a 1275gt kit but I'd still be left with no top radiator hose. Also, £105 is a bit much to be waiting 8 weeks!
Posted 06 May 2015 - 09:14 PM
If its got a thin layer of clear over it, then there is noting to do really. Seems like a lot of extra work just to keep their logos from coming off!
Acetone isnt too strong for pure silicone - i use it everyday with no problems. Not sure what the makeup of the hose silicone is, but it may be that the others that have used acetone have gone to town and abraded the surface, and then blamed the acetone!
Never understood the need to over logo products, a discreet logo here and there is fine but some manufacturers do go OTT.
Posted 07 May 2015 - 07:56 AM
I hated the massive in your face logo as well, I very carefully scratched mine off a year ago with a scalpel.
Posted 07 May 2015 - 11:20 AM
Mines have some other logo on them, they were purchased from mini spares though. I guess as long as it does the job no one is going to see most of the time?
Posted 07 May 2015 - 03:58 PM
You could try that, just treating the end 1/2 inch, then eave it a while. If it's degraded, cut it off. If no harm done, be braver.
Alternatively, keep the bonnet closed.
Posted 07 May 2015 - 04:11 PM
yeah i have some blue ones from minispares with the logo on. the logo almost seems to be silicone based itself so nothing touched it when i tried to get it off.
even tried sanding one of the logos off using some fine grit sandpaper, it did not work just made it look like something had been rubbing on the pipe.
grab a black sharpie pen and fill in the logo?
Posted 07 May 2015 - 06:16 PM
