Rover Cooper Sport (2000) - Dashboard
9 replies to this topic
#1 ClaireDB
ClaireDB
  • 11 posts
Posted 07 May 2015 - 10:51 AM
Hey!
I was wondering if anyone has any suggestions on how to get around the dashboard getting loose? My dashboard is tightly fasten at the bottom with the 3 bolts but the top brackets are useless.
If I push against the dash when it vibrates it stops, I just need some way of getting it fastened tighter so it stops rattling.
Any help would be appreciated.
Many Thanks.
#2 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 07 May 2015 - 12:17 PM
It might help to put the anti rattle strip round it if you haven't got it. Mine was rattling and it was the holding brakets rattling on dash frame, I took them out and put rubber on ends.
#3 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 09 May 2015 - 06:34 AM
The central top clip may not be catching, also helps for someone to push the desk in as far as you can while you tighten the nuts up
#4 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 17 November 2015 - 01:26 PM
Does anyone have a solution to the loose dashboard problem? I was thinking about making up some brackets to be secured on the top and bottom rail like the aftermarket dashes come with. The ones with the wing nuts for example.
#5 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 17 November 2015 - 01:43 PM
I had a similar issue with my Cooper S. I removed the dash, bent the brackets up a little more then refitted. Solved the issue.
#6 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 17 November 2015 - 01:47 PM
The brackets on the Cooper Sport 2000 dash are plastic
#7 jamesquintin
jamesquintin
  • 1,017 posts
Posted 17 November 2015 - 05:19 PM
try screwing the brackets into a different place, the wood on mine was a bit loose
#8 TiMtImInYtImTiM
TiMtImInYtImTiM
  • 75 posts
Posted 24 November 2015 - 12:27 PM
The plastic brackets are terrible on the MPI dash. They have just lost strength over the years and now cant hang on.
#9 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 25 November 2015 - 10:47 AM
As someone that has done this to their own cooper sports - The clips are plastic. The brackets are metal. I removed the clips and bent the brackets to add more sprung tension to the top of the dash.
Edited by Steve220, 25 November 2015 - 10:50 AM.
#10 Midas Mk1
Midas Mk1
  • 5,779 posts
  • Local Club: S.U.N.M.C
Posted 25 November 2015 - 10:53 AM
+1 - on my Cooper Sport, the brackets had come away from the wood rear of the dash, pulling the self tappers out, and causing slack / ill fitting.
My dad knocked up some metal support brackets to attach to the wood, then the original brackets to be fixed to, problem solved, nice tight fitting dash. :thumbsup:
Edited by Midas Mk1, 25 November 2015 - 10:53 AM.
