Hi;
I asked or read this a long while ago but cannot find the thread.
As a result of another thread I bought some P Clips and 5mm Bolts and Nuts for fitting the Fuel, Brake and at the time the Battery Cable.
My floor repairs are now complete but am still in the process of repairing the Flitches so I don't want to paint yet. Before I do paint however I still need to weld in the 5mm bolts for the Fuel and Brake Lines.
The reason for this thread is that I am not 100% sure where I am going to route the Battery Cable (I do intend to route it through the inside of the car). I don't want to guess in case it affects the new carpet and ends up making a mess of the interior.
Because of this uncertainty I am not able to drill holes and weld the 5mm bolts for the P Clips that will secure the Battery Cable but don't want this to delay the build.
I am now considering stick on pads and cable ties to hold the cable in place on the inside this way I can finish the repairs, paint the inside and fit the cable whilst I am fitting the carpet and interior trim.
Couple of questions:
1. What is the best routing for running the cable inside?
2. Does anyone have a better idea on how to secure the cable?
From what I remember my plan and advice was to drill a hole in the bulk head inside the engine compartment and run the cable along the tunnel, through the Cross Member, along the cross member behind the front drivers seat. along the Inner Sill, along the base of the companion bin, under the rear bench, up through the rear bench and into the boot (possibly drill a hole in the back of the rear seat?
