Rear Quarter Panel
4 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 08 May 2015 - 06:30 PM
Hi all,
As always need some advice please on the following;
What is the sealant you might be able to see on the rear quarter panel and waist rail ? was it applied before or after being spot welded ? is it necessary ?
Secondly is it best to joggle the rear quarter panel or butt weld when replacing and where's the best place to cut and join please
see pics thanks
P.S is this too many spot welds on the sills ??
Attached File  20150508_152252.jpg   40.3K   16 downloads Attached File  20150508_171122.jpg   34.77K   17 downloads Attached File  20150508_171132.jpg   42.48K   16 downloads Attached File  20150508_171139.jpg   35.53K   10 downloads  Attached File  20150508_171145.jpg   36.57K   12 downloads
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 May 2015 - 06:45 PM
I'm not sure that is sealant. looks to me like old waxoil residue. I had it on mine too.
When you put the new panel on, all there is any need for between the flanges is some zinc weld thru primer.
As for the spot welds, possibly a bit overkill but it won't be an issue.
I would but weld the joins on the B and C pillars as they are only short sections so not much chance of distortion and the join will be no weaker than a lap joint but much easier.
Ben
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,074 posts
  • Name: Neil
Posted 08 May 2015 - 06:51 PM
Mmm shouldn't be any sealant on the waist rail, maybe some on the bottom of the quarter panel to sill joint. And as Ben has said butt weld the B and C pillars.
#4 I hate Brian
I hate Brian
  • 782 posts
Posted 08 May 2015 - 09:05 PM
Cheers guys
#5 spiguy
spiguy
  • 1,537 posts
Posted 08 May 2015 - 10:19 PM
looks like wax to me too.
