Brake Pad Fallen Out!
brakes
5 replies to this topic
#1 Chelsea_Pete
Chelsea_Pete
  • 66 posts
  • Local Club: London & Surrey MOC
Posted 09 May 2015 - 07:22 PM
Hi all, got an unusual one here..
Heard a grinding coming from my front brake earlier in the week, assumed the pad had worn down to the metal so ordered a new set plus discs as i knew they were on their last legs.
When I got the wheel off today I found one of the pads had gone missing, the grinding noise had been the piston on the disc!!
What i need to know is why this may have happened, as I can see nothing wrong with my caliper, all split pins in etc.
Really don't want this to happen again and ruin the new disc or worse, cause an accident!
Cheers, Pete
#2 petey81
petey81
  • 1,352 posts
Posted 09 May 2015 - 07:37 PM
Get up some pictures
#3 Chelsea_Pete
Chelsea_Pete
  • 66 posts
Posted 10 May 2015 - 12:10 AM
Not an awful lot to see now im afraid as the pads and disc have been replaced
#4 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 10 May 2015 - 05:08 AM
If the split pins that hold the pads in place are still in tact, I can only guess the pads were never in properly or they failed at the split pin hole?
Edited by JackF, 10 May 2015 - 05:08 AM.
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 10 May 2015 - 10:24 AM
Or the pad broke up an the backplate got twisted and bent enough to go through the the gap between the split pins
#6 Jon937
Jon937
  • 130 posts
Posted 16 June 2015 - 09:06 PM
I think JackF has the answer as there is no reason the pad should ever come off the split pin unless both pins had broken.
Also tagged with one or more of these keywords: brakes
