Ive got a 16 blade metal fan but im not sure which way round it goes? the blades either bow out in the middle or in depending on which way round, surely it goes the way that you cant see the back support type brackets doesnt it?
I will try and put a pic up tonight to explain it better but any ideas?
Cheers Simon
Which way round does the fan go?
PhoenixSimon
, Jul 24 2006 10:52 AM
6 replies to this topic
Posted 24 July 2006 - 10:52 AM
Posted 24 July 2006 - 12:07 PM
Stand at the front of the car and look down at the engine. While running, the fan turns away from you toward the firewall. You want the blades cupped such that they scoop air from the engine compartment and blow air through the inner wing onto the front tire.
..............Fan
engine---- ( -------- radiator
..............Fan
Edited by dklawson, 24 July 2006 - 12:07 PM.
Posted 24 July 2006 - 02:11 PM
ahhh I get what you mean, I will try and take a pic when I get in to make sure.
cheers Simon
cheers Simon
Posted 24 July 2006 - 02:28 PM
If you look down on the engine from above, the fins should be (engine) / (rad), not (engine) \ (rad), if you get that!
Posted 24 July 2006 - 04:16 PM
The MG-1100 and Austin America both used transverse A-series engines so their basic layout was identical to the Mini. Take a look at this site for more info on cooling:
http://members.tripo...erica/id77.html
Posted 24 July 2006 - 08:19 PM
cheers dklawson interesting site.
the fan is shiney side out so I will see the chrome side.
Took a pic with effectively engine on the left and rad on the right as if you were looking down on it from the front of the car, and this looks right.
cheers Simon
cheers Simon
Posted 24 July 2006 - 08:39 PM
yep i think thats the right way round
