Mpi Fuel Pump Spade Connector
BritishRacingGreen
, May 10 2015 12:25 PM
3 replies to this topic
Posted 10 May 2015 - 12:25 PM
I'm after the connector that plugs into the top of the MPI fuel pump assembly, if anyone has an old MPI loom lying around and would mind snipping the connector with a couple of inches of wire off so I can splice into my existing wiring.
Failing that if anyone has the rear section of the loom completely, from front to back I'd consider buying the whole thing if you didn't want to chop off one connector.
Send me a PM on here if you can help
Posted 11 May 2015 - 12:46 PM
I may have a connector in stock - can you show me where it plugs onto?
Posted 13 May 2015 - 01:25 PM
This is the original plug I believe:
But i'll just order a new one from polevolt as I need some other wiring items. Thanks though
Thanks Andy, looking for some other wiring stuff I found these, which look closer to the picture above. I'll order both and see which works. thanks.
http://www.polevolt....info_RS635.html
Edited by BritishRacingGreen, 13 May 2015 - 01:28 PM.
