Suspension/ride Height Woes
5 replies to this topic
#1 Shaley
Shaley
  • 154 posts
Posted 12 May 2015 - 09:10 AM
Ok here goes
New set up adjustable gaz dampers new hi lows with coil springs (i know the purists will say go rubber but its what my son wanted)
set the ride height quite high as knew things would settle down. mile down the road started ribbing on the arches..! returned home then after a few mins height returned??
Would up even higher and resolved the problem of the rubbing but the car looks like a 4x4 lol as it keeps rising up?
Is this just the springs bedding in as it were and need to compress to there own level? just cant understand the rising back up?
Thanks in advance
#2 nicklouse
  • 18,658 posts
Posted 12 May 2015 - 09:32 AM
sounds like you have the shocks set with to much rebound so it is packing down.
solution reduce rebound.
#3 Shaley
Shaley
  • 154 posts
Posted 12 May 2015 - 05:44 PM
As in set too stiff or not stiff enough??
#4 firstforward
firstforward
  • 824 posts
Posted 12 May 2015 - 05:57 PM
You might get a nominal amount of settling with coil springs after a month or so but for the purpose of your problem no. Where did you buy the springs from and what rating are they?
#5 nicklouse
  • 18,658 posts
Posted 12 May 2015 - 07:27 PM
way too stiff. They are not opening fast enough.
#6 Cooperman
  • 23,319 posts
Posted 12 May 2015 - 08:32 PM
That is why coil springs are a very poor idea. It's not a case of being purist, it's a case of coil springs being unsuitable for general use due to the need for accurate rising rate of springing which only the rubber cone springs can give with such short suspension travel.
Coil springs are for racing on totally smooth tracks where a high initial rate is needed to enable the damper settings to be set for race conditions.
