Electrical Whirring Noise On Before Ignition
8 replies to this topic
#1 morganb3
morganb3
  • 42 posts
Posted 14 May 2015 - 05:59 PM
Hi,
As mentioned in the title, I have a whirring noise that occurs at the first turn of the key, Must be electrical as the engine isn't turning over. It is worse in the cold as well.
It isn't an Issue but i would like to put my mind at ease. It is a 1997 MPI.
#2 steve m
steve m
  • 78 posts
Posted 14 May 2015 - 06:11 PM
Sounds like an electrical fuel pump, has it got one
#3 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 May 2015 - 06:36 PM
^ +1
#4 morganb3
morganb3
  • 42 posts
Posted 14 May 2015 - 07:25 PM
Yes it does, But does that prime on the first key turn? It doesn't fade either.
#5 Dusky
Dusky
  • 5,322 posts
Posted 14 May 2015 - 08:57 PM
Record it, New pumps don't stop
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 14 May 2015 - 11:57 PM
It's an MPi fuel pump primes the system on turning the key. Open the boot lid and you'll hear it louder.
It's supposed to do that, unless you have another problem?
FS
#7 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 15 May 2015 - 02:37 AM
I have the same on my spi, it's nothing to worry about. Just the electric pump priming and pressurising the fuel system.
#8 maccers
maccers
  • 1,872 posts
  • Local Club: LSMOC
Posted 15 May 2015 - 05:36 AM
As above, I have an MPI fuel tank in my custom setup, and with ignition on the fuel pressure guage on the regulator shows fuel pressure before engine running.
#9 morganb3
morganb3
  • 42 posts
Posted 15 May 2015 - 09:40 PM
I Have found it. I have the standard fuel pump whirring, after that finishes it starts. I have traced it to the heating system at the centre console so shouldn't be a massive issue......
