Torque Setting For Thermostat Housing Bolts?
3 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 May 2015 - 11:44 AM
As above, anyone have this info to hand?
Craig
#2 Cooperman
  • 23,356 posts
Posted 19 May 2015 - 11:47 AM
The thermostat housing should have studs and nuts (5/16" UNF).
Just 'nip' them up by hand without distorting the gasket and it will be fine.
#3 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 May 2015 - 11:48 AM
super! thanks for the quick response
#4 carbon
carbon
  • 2,590 posts
Posted 21 May 2015 - 06:35 PM
The A+ motors often have bolts fitted, but studs and nuts are better.
If you do refit thermostat bolts use copious amount of copper grease on the threads. Without grease they have a tendency to rust in and then shear when you try and get them back out a few years later...
