I drained and flushed my coolant over the weekend.
Removed the bottom hose, then put a garden hose into the radiator cap and flushed the radiator.
I then removed the thermostat and flushed the block.
Just so I am clear about the the filling procedure. Do I fill the block at the thermostat housing, refit the thermostat and then fill the radiator.
Do I then leave the radiator cap off to bleed the system, I guess I need to leave the car to get to temperature so the thermostat opens.
