Top Rail Ash Tray Conversion.
3 replies to this topic
#1 Juniors mini
Juniors mini
  • 93 posts
Posted 19 May 2015 - 07:59 PM
I stripped out the top rail so I can recover it (same material as doorcards) and fit a amp meter and volt meter and a digital tempture gauge, fitted them so I can see what's going on with the amps V/A and temp.
Just need to pop them out cover it then reinstall it.
Attached File  image.jpg   78.52K   15 downloadsAttached File  image.jpg   68.12K   10 downloadsAttached File  image.jpg   96.32K   5 downloadsAttached File  image.jpg   64.97K   9 downloadsAttached File  image.jpg   66.77K   39 downloadsAttached File  image.jpg   58.8K   23 downloadsAttached File  image.jpg   57.25K   17 downloads
#2 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 22 May 2015 - 10:34 AM
That's a really neat idea.
#3 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 22 May 2015 - 11:24 AM
Looks good. My only comment would be that an ammeter isnt entirely necessary with a voltmeter as they are proportional, provided resistance doesnt change. You are also sending an awful lot of current wizzing around your dash when using an ammeter and you need to make sure you have suitable cable to top it off. Otherwise you could end up with a very big fire risk.
#4 Juniors mini
Juniors mini
  • 93 posts
Posted 22 May 2015 - 11:39 AM
The ampmeter has a 200amp shunt which will be in the boot and from there a 20awg wire feeds to the meter in the dash in MV so not alot of power will be buzzing around the dash.
Edited by Juniors mini, 22 May 2015 - 07:47 PM.
