Which oil???
Posted 25 July 2006 - 10:55 AM
Posted 25 July 2006 - 10:56 AM
Posted 25 July 2006 - 10:57 AM
Posted 25 July 2006 - 01:35 PM
The most important thing to remember with an auto Mini is to change the oil and filter no later than every 3000 miles. This is extremely important for the function of the gearbox. The oil gets sheared and chopped up a lot in a Mini engine and soon becomes unreliable for use in the gearbox hydraulics.
Posted 25 July 2006 - 02:26 PM
Posted 25 July 2006 - 02:53 PM
Posted 25 July 2006 - 03:11 PM
Posted 25 July 2006 - 04:22 PM
I may be able to dig it out.
Posted 25 July 2006 - 04:36 PM
auto minis as well
As well as what? That's exactly what's been said above!
Tesco oil is about as good as Tesco petrol. And Tesco value oil is even worse. As you've said, clean oil is essential so why would you use something made from recycled petroleum byproducts filled with viscosity enhancers in a desperate attempt to force it to hold together. Always use good quality oil.
In theory a 20w50 will be a better quality oil than a 10w40. Although the viscosity band is the same, the starting point (the 20 bit) is heavier so on theory needs less viscosity enhancers to keep it thick when hot. If you can find an oil that has the viscosity it is labelled with without needing any enhancers to get that performance it will be better.
You might find that in the winter with a 20w50 starting will be a bit harder and thinking about it now in an auto it might affect the operation of the torque converter until warm but shouldn't affect the gearbox itself much.
Edited by Dan, 25 July 2006 - 04:37 PM.
Posted 25 July 2006 - 05:00 PM
I've heard that the answer for Minis is "don't", reason being that they aren't designed with gearboxes in mind. I kind of get that, but then Mineral engine oils aren't either - gearbox oil is designed for gearboxes, and obviously isn't an option!
Would any harm really come from using Synthetic or semi in a mini?
Posted 25 July 2006 - 05:08 PM
Posted 25 July 2006 - 05:34 PM
Posted 25 July 2006 - 10:10 PM
auto minis as well
basicaly dont let it go dark brown or black! can happen before 3000 miles especialy on an older and worn engine! gees snippy remarks like that reminds me of Minifinity!
all because it says tesco value doesnt mean its automaticaly rubbish!! its basicaly esso grade oil just with a different brand name! cheap as only older cars use it! and as their are more modern cars which require modern synthetic oils the price is jacked up on them, as more demand = more expensive, but hay what would i know! i'm not an oil chemist!
Edited by Jay3178, 25 July 2006 - 10:57 PM.
Posted 25 July 2006 - 10:25 PM
The better quality and quantity of additives in the oil (within reason) mean a better oil and you pay for this !!!
Cheap Tesco oil wil have the minimum amount of cheap additives in it to pass whatever spec they are quoting on the side of the can !!
As for oils going black then this is GOOD !!! If your oil never goes black then its not doing its job !!!
Your engine produces millions of particles of carbon and dirt and a good oil has two specific additives in it to handle these....a detergent and a dispersant!
The former stops the particles from sticking to anything and the dispersant then traps each of these particles and holds them in suspension in the oil so when you drain it they fall out with the oil. These particles in the oil are what make it look black. If its not black then the oil is not holding the particles and they are scattered throughout your engine, slowly building up into large deposits to stick your rings and block your oilways !!!
My background is working for the world leader in lubricant additives so up to you if you believe me or not !!!!
Posted 25 July 2006 - 10:57 PM
not for an automatic gearbox! darkened oil causes problems with the gear hydrolics! hence why modern auto engines have the gearbox fluid seperate as to keep it as clean as possible to give smoth running, one problem the mini unfortunatly has in sharing oil with engine! hence why i said clean oil is the key to a good running auto mini!
