Electric Cooling Fan
6 replies to this topic
#1 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 25 May 2015 - 06:11 PM
can anyone please tell me how to wire in a electric cooling fan into a switch on the dash
thanks
#2 Cooperman
  • 23,326 posts
Posted 25 May 2015 - 06:28 PM
You need a relay and two fuses. Run a signal lead from a power source via a 5 amp fuse to the dash switch and thence to the relay.
Run a power lead from a power source to a 8 amp fuse and thence to the relay 'power-in' terminal.
Run a power lead from the relay 'power-out' terminal to the fan.
Run an earth lead from the relay earth terminal to earth and another earth from the fan earth terminal to earth.
Use the correct cable sizes to suit the power figures supplied with the fan.
#3 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 25 May 2015 - 06:34 PM
thanks for your reply what type of relay do I need
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 May 2015 - 08:40 PM
12v 40 amp 4 terminal type Relay
Quoting Cooperman above
Run a signal lead 0.5mm 16/0.20mm Thin Wall Cable Nominal Current Rating: 11.0 amps from a power source via a 5 amp fuse to the dash switch and thence to the relay.  TERMINAL 86
Run a power lead 2.0mm 28/0.30mm Thin Wall Cable.Nominal Current Rating: 25.0 amps from a power source to a 8 amp fuse and thence to the relay 'power-in' terminal. TERMINAL 30
Run a power lead 2.0mm 28/0.30mm Thin Wall Cable.Nominal Current Rating: 25.0 amps from the relay 'power-out' terminal to the fan. TERMINAL 87
Run an earth lead 0.5mm 16/0.20mm Thin Wall Cable Nominal Current Rating: 11.0 amps from the relay earth terminal TERMINAL 85 to earth and another earth from the fan earth terminal to earth.
Thicker wire gives less volt drop to the fan and the earths will be blacks, use what colour you fancy for terminal 30 and out on 87 to the fan but the standard Fan Colour feed was Black/orange when used from fan to thermo switch
Edited by KernowCooper, 25 May 2015 - 09:02 PM.
#5 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 26 May 2015 - 05:49 AM
thanks for your help
#6 Cooperman
  • 23,326 posts
Posted 26 May 2015 - 09:05 PM
It is good to have a 'proper' electrical specialist on here Dave. I'm a mechanical engineer and tend to over-simplify electrical stuff :D .
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 May 2015 - 09:17 PM
No probs mate, i just saw what the next question/s would have been to help to OP out, I just used your reply with a bit added in red to save a lot of one finger typing
